1998 Blade Fairing Bolt Question - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-04-2004, 11:46 PM Thread Starter
I have lost my front fairing bolt that is located between the position light and the headlight, that is dead centre at the front of the blade.
I have purchased a new one but when it is tightened up there is about 3 mm gap between the bolt head and fairing. I do not recall any washer to make up the gap.
The Honda dealer and I have checked the part number and it is the right one. I have swapped out the same size bolts from the rest of the fairing but all sit about 3 MM proud when put into the front location.
Has anyone struck this problem or is their a washer to go under the bolthead ?.
old1 is offline
post #2 of 5 Old 12-05-2004, 5:43 AM
Re: 1998 Blade Fairing Bolt Question
I'll go check for you in the morning. The house is asleep except for me, even the dog on my right foot. Don't want to go stumbling through the house and into the garage right now.
66droptop is offline
post #3 of 5 Old 12-05-2004, 6:52 AM
I have looked at the micro fiche, my service manual and my bike. There is no washer on that fastner, or any evidence of one on mine. The only thing I can think of is that the fairing is caught up on the threads and is getting pinched, making the bold seem tight, instead of sitting on the shank. That hunch is obviously a "dunno what else" thought...
Goose is offline
post #4 of 5 Old 12-05-2004, 4:46 PM
This is what happens when you try to help.
Took out the fairing centre bolt. Took out one of the tailpiece bolts. Compared the two. Identical.
Put back the tailpiece bolt and cross threaded it. Bastard!!
Anyway. The bolts are the same. If you cant get yours to fit I suspect one of two things.
1. The shoulder of the bolt is resting on the edge of the hole in the fairing instead of passing all the way through.
2. you have trapped a piece of the wiring harness between the fairing and the bracket.
Good luck
Bill
gayblade is offline
post #5 of 5 Old 12-06-2004, 5:49 AM Thread Starter
66droptop - I will be interested in what you find when you get to have a look.
Goose - I have done the same and the dealer and both of us are none the wiser. A real mystery.
Gayblade - sorry about that but your help is appreciated. A cable caught behind would actually help. I does make me wounder if there was not something that sits under the fairing against the mounting bracket to make up the space?. I have checked the shoulder of the bolt and it is clear of the fairing hole.
There is an identical blade to mine in the next suburb so I will try and keep an eye out for it and have a look.
Thanks all.
old1 is offline
Technical-Head/Camshaft assembly question victoRR Honda FireBlade 15 11-16-2004 11:18 PM
question for pre 2000 blade owners.. CBRSP2 Honda FireBlade 2 10-19-2004 4:58 PM
Hindle Bolt on question jaim Honda FireBlade 2 07-12-2004 5:25 AM
Track Fairing Question...please help Duke Honda FireBlade 2 09-24-2003 9:17 AM
fairing stay question twipper Honda FireBlade 0 05-23-2003 1:34 AM
