929 won't start. Help! - Honda Motorcycles - FireBlades.org
post #1 of 24 Old 12-05-2004, 12:13 PM Thread Starter
Sequence of events:
-929 battery is low/dead from lack of use.
-Tried to bump start but couldn't get enough speed.
-Put 929 on battery tender for 2 days to charge.
-Light green, charged battery.
-Take battery tender off, bike starts just fine.
-Put the battery tender back on just in case.
-Next day, remove battery tender.
-Bike turns over and over and over, no ignition.
-Checked all fuses, everything fine.
-Lights come on
-Fuel pump comes on.
-Battery is charged.
WTF? Anyone have a next course of action? What should I test next? I have a multimeter but just unsure of direction to go with this. Could I have blown my ECM? I figured the fuse would have blown if a surge went to the ECM. I don't see any error codes when I turn the bike to on but I'm not sure if they display like that or if you need a Honda diagnostic computer. Help!
-Shrub
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
WetShrub is offline
post #2 of 24 Old 12-05-2004, 12:46 PM
Re: 929 won't start. Help!
What's the voltage out of the battery ... if you don't charge it?
SpikedLemon is offline
post #3 of 24 Old 12-05-2004, 1:10 PM
Fire929blade's Avatar
Reputation Power: 17
You should not need anything extra to read the fault codes.. You can read the number of short and long blinks in the oil pressure/FI light (the red one)
I would go for a new battery first. Even if it cranks the engine, it might not have enough power to the FI/ingition system.. ? There have been many strange problems which have been solved with a new battery.
Hope you can fix it fast and not to expensive!!
My gallery
and do check out Freeloader My sister is the voice
Fire929blade is offline
post #4 of 24 Old 12-05-2004, 2:38 PM Thread Starter
I don't have a digital mutli-meter but the voltage is a little over 12v. Perhaps you are right about the battery. I just charged it fully and tried to start it. It cranked a couple times and ignited for probably 1 or 2 revolutions and then died again. Then I couldn't get it started after that. Not enough output?
No blinking on the red light or the FI light. At start up the FI is on, then it goes off and the red check engine light comes on and stays on....no blinks.
Battery runs down pretty quickly when I am cranking the engine too so I bet it would be the battery. Since I tested it after charging it I bet it's putting out a false signal... Not really holding any juice.
WetShrub is offline
post #5 of 24 Old 12-05-2004, 2:50 PM
Battery for sure Go get a new one
My gallery
post #6 of 24 Old 12-05-2004, 6:27 PM
I'll vote battery too. It's the price we pay for light weight.
Joel is offline
post #7 of 24 Old 12-05-2004, 7:03 PM Thread Starter
Yeah, I should be thankful it's not something more expensive. Just to be sure I have a Kragen right around the corner. I'll have them load test the battery and then ditch it. Aren't you supposed to replace those things every 3 years or so anyway?
WetShrub is offline
post #8 of 24 Old 12-05-2004, 9:58 PM
CBR929RE's Avatar
Reputation Power: 39
I pulled my battery out the other day for winter and it appears to be the original. Threw it on the charger and I checked it a few hours later and it was fully charged. looks like the previous owner kept it up pretty good.
CBR929RE is offline
post #9 of 24 Old 12-06-2004, 1:03 AM
If you winterize your bike, a battery tender or some other intellegent charger will pay for itself the first Winter IMHO.
Joel is offline
post #10 of 24 Old 12-06-2004, 6:53 PM
That's a fact! shrub, count me in with the others who suggest a new battery.
Bacchus is offline
post #11 of 24 Old 12-07-2004, 6:37 PM
davef's Avatar
cbrF3 battery from Kmart=$50 and it works in a 929!
2002 954 Full Ohlins, Galfer Wave Front Rotors, Scotts Damper, MIG High Mount, 16/45 520 Conversion...Sweeeeet
1996 CBR600F3 Smokin Joe's Edition
Gets good MPG...
davef is offline
post #12 of 24 Old 12-11-2004, 6:45 PM Thread Starter
Had the battery tested....it's fine. Now I guess I will check for spark? Pull a plug, ground it and check for spark. If I got no spark then it's the coil?
WetShrub is offline
post #13 of 24 Old 12-12-2004, 8:36 AM
Strange! Your bike has separate coils for each cylinder, and they are built into the sparkplug caps. They are activated by the ECM. You could always pull a plug and see if you have nice powerful spark but I doubt if all the coils are broken. If you have a good spark, the next step would be to check if the injectors are activated so the engine gets fuel.
With fuel, ignition, correct engine timing and compression it should start..
Best of luck!
My gallery
post #14 of 24 Old 12-12-2004, 11:49 AM
Regardless of the load test, I would be highly skeptical of a battery that is showing ca. 12V.
redcliffs is offline
post #15 of 24 Old 12-12-2004, 1:15 PM
Did you hit the kill switch by chance ?, or maybe out of gas.
oldgoat is offline
100,000 kms on a 929 omen137 Honda FireBlade 20 10-08-2004 12:21 PM
929 almost stolen Grunt Honda FireBlade 14 07-08-2004 11:51 PM
929 wont start 929rrrider Honda FireBlade 8 10-24-2003 11:34 AM
929 doesnt have spark?..wont start apok408 Honda FireBlade 9 08-23-2003 11:30 PM
929 will not start after valve check Seeker Honda FireBlade 18 08-20-2003 10:20 AM
