954 fork preload question - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 12-06-2004, 2:12 AM Thread Starter
ndj
Reputation Power: 15
To save me the trouble of winding the fork preload from one extreme to another: does anybody know how many turns it is from full soft to full hard. The manual says the standard preload is 7 turns from full soft (for those who don't know, 954 forks don't give any external indication of what the preload is set to).
Another question is: what fork preload should be dialed up for aggressive riding on curvy, bumpy roads as opposed to on a smooth racetrack? (solo rider 80kg/176lb)
ndj is offline
post #2 of 7 Old 12-06-2004, 2:48 AM
Jungleboy's Avatar
Re: 954 fork preload question
From memory I think its about 14 turns (+/- 1?) you should adjust it so that you have about 30-38mm of sag with you sitting in the riding position with all your gear on. Closer to 30mm for the race track and and more towards 35 for the road although your riding style and individual preference also factor in. Also make sure the rear is set properly 28-35mm, again the smaller number for the track. If you add a reasonalble amount of preload you may then need to add some more rebound damping!
Ps. at 80kg the standard 954 front springs are too soft for all but touring! I would recomend 0.90kg/mm or 0.95kg/mm for your weight!
2004 1000RR Racebike
www.jungleboyracing.com
Jungleboy is offline
post #3 of 7 Old 12-06-2004, 3:45 AM Thread Starter
ndj
Are you saying I'm fat?
Thanks for the advice. As it happens, my wife will be riding this bike when we go riding together and as she weighs less than me (I'm not saying how much exactly as she may 'spy on me' and read this) I'll probably set it up a bit soft anyway.
Is the sag you recommend over and above the static sag of the bike's own weight? Or do I have to lift the bike up to measure from the fully extended fork position? (that would prove a little problematic me thinks).
ndj is offline
post #4 of 7 Old 12-06-2004, 5:40 AM
Jungleboy's Avatar
It is the total sag from the fully extended position, Its less than ideal but you can always pull the bike on to the side stand until the wheel comes off the ground and have an assistant measure it
post #5 of 7 Old 12-06-2004, 11:13 AM
With your weight (or any weight really) you'll never get close to the correct sag with stock springs...sorry but the stock stuff is some of the worse suspension out there.....way too undersprung...junk! Send'em to DK for work.
02FBlade is offline
post #6 of 7 Old 12-06-2004, 7:09 PM
Agreed - The stock suspension is complete junk. Dan Kyle is the man to talk to about having it re-sprung for ANY weight.
NineFiftyFour is offline
post #7 of 7 Old 12-06-2004, 9:03 PM
CBRBob's Avatar
I tried setting the sag for a 160lb rider. The best I could get was 2in sag
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
what weight rider are the stock springs set up for n.e.o. rider General Discussion 18 03-06-2004 3:33 PM
954 Fork question chrisbratton22 Honda FireBlade 6 01-02-2004 3:48 PM
Bike Handles Like Ass GoatRacer Honda FireBlade 22 10-17-2003 6:14 PM
954 929 fork question LNSPLTRS Honda FireBlade 1 08-22-2003 8:20 PM
Suspension Question about preload? K9inAZ Honda FireBlade 2 08-11-2003 2:10 PM
