speedo wire for cbr900rr - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-31-2004, 10:33 PM Thread Starter
hi guys i was wondering if any one here could tell me how to hook up my speedo guage soo that it works on my 94 cbr 900 rr. i kno that it uses a cable but i do not know where it goes on the engine block. any help will be appericated. thanks
Cbr_rAcEr_11 is offline
post #2 of 5 Old 12-31-2004, 11:06 PM
Re: speedo wire for cbr900rr
For some reason I think the early 900's have some weird setup with the front tire. But I really don't know much about the early 900. I DO know my '98 has a 3 wire sensor from the top of the gearbox. If you remove the tank, it is directly below it (look straight down), mounted into the top of the housing, a little to the right of the starter. It will have a green wire, pink wire, and black wire. If I remember correctly, black was positive, green was the ground, and pink was the sensor signal from the sensor to the speedo.
I only know this because I recently installed a Yellow Box speedo recalibrator to compensate for my new gears.
But like I said, I'm not sure about those early models. And my service manual doesn't cover your year.
66droptop is offline
post #3 of 5 Old 01-01-2005, 1:04 PM
That is correct. The CBR 900 used a front wheel speedo unit until '97. Your cable will connect to one of the wheel spacers - I believe the left side, but it's not like it would be that hard to figure out, as there are only two to choose from.
BDA116 is offline
post #4 of 5 Old 01-02-2005, 6:29 PM
95 RRS was the last model to us a cable speedo RRT's on have electronic
RRTSean is offline
post #5 of 5 Old 01-02-2005, 9:38 PM
cbr99xx's Avatar
Quoted: 27 Post(s)
Reputation Power: 27
My '95 had no cable, the electronic sensor was on the counter shaft sprocket.
http://www.ronayers.com/fiche/200_03...eter_95-97.cfm
http://www.ronayers.com/fiche/200_03...eter_93-94.cfm
Life always looks better through bugs on a face shield.
cbr99xx is offline
Recalibrate Speedo? Hellfire666 Honda FireBlade 7 12-03-2007 9:21 AM
2003 954 extra wire :( Hellfire666 Honda FireBlade 7 04-29-2004 4:05 PM
how to determine wire polarity stegen Off-Topic 15 04-02-2004 12:49 AM
Speedo Error? Voodoo954 Honda FireBlade 7 03-06-2004 4:03 AM
Jumper Wire BushrodW Honda FireBlade 5 06-18-2003 4:15 PM
