bike wobbling - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 01-05-2005, 4:02 AM Thread Starter
Ray
bike wobbling
my bike seems to be wobbling or nervous in the corners.. i'm not even going really low in the corners..
some problem that i can think of..
1. the rear wheel bearing is gone (but i just change mine, unless its not
properly fit).
2. the wheels not properly balance.
3. my front wheel bearing gone (took out my brake pads and spin it.. seems
ok and not shaking)
4. alignment problem (i didn't even drop my bike before).
5. clamp is slant to one side when going straight.. but it hasn't been e
problem till recently.. so i don't think it's related..
so any idea whats happen??
anyway.. can someone teach me how to align my front.. after changing my cone bearing, the clamp on top seems like slant to right side(right side nearer to the tank) when going straight.. didn't drop before so i don't think anything thats bend.. i tried lossening all the bolts and compress e front (tought in the magazines) but it doesn't works..
Ray is offline
post #2 of 12 Old 01-05-2005, 5:36 AM
Re: bike wobbling
when you say wobbling, what exactly do you mean, does it feel loose and unstable in a lean, left or right corners?
Look, Lean, Believe..
CBRSP2 is offline
post #3 of 12 Old 01-05-2005, 9:27 AM
ReaperAZ's Avatar
Reputation Power: 24
Send a message via AIM to ReaperAZ Send a message via MSN to ReaperAZ Send a message via Yahoo to ReaperAZ
Re: bike wobbling
Is it wobbling when you are coming into the corner off the gas? When you are gong though the corner holding steady? When you roll on the gas for the exit?
Dano
Dan
ReaperAZ is offline
post #4 of 12 Old 01-05-2005, 11:10 AM
Re: bike wobbling
Assuming there is nothing broke/bent/loose bearing...the stock suspension will wobble. I always had a wobble, espeically through a ciciane (transitioning from side to side)...I'd have to let the wobble settle then lean it in. Even w/ Ohlins 3way and DK forks I still have a slight wobble but it's nothing compare to the stock crap!
02FBlade is offline
post #5 of 12 Old 01-05-2005, 1:38 PM Thread Starter
Ray
Re: bike wobbling
actually feels like something is loose.. much worst in the left bend.. usually on really long left bend (where u can really feel hows the bike is handling) when i'm off the gas or throttling a bit in mid corner to maintain my line..
right hand bend theres still a little of wobbling but not that worst..
i'm not pushing my bike.. doing around 80km/h (50mph) on a left bend.. not at full lean maybe just 45degree only..
Ray is offline
post #6 of 12 Old 01-05-2005, 7:21 PM
RPinOZ's Avatar
Re: bike wobbling
Are you sure it was reassembled correctly after replacing the wheel bearings?
my bike
I'd like to die peacefully in my sleep like my grandpa
not screaming in terror like the passengers in his car.
RPinOZ is offline
post #7 of 12 Old 01-05-2005, 7:35 PM
Re: bike wobbling
Besides what's been mentioned, do you have good rubber on the bike? Is it cupped? Is there any damage to the tires (patched holes, bulging, etc)? Is the air pressure correct?
2OHOH2 is offline
post #8 of 12 Old 01-05-2005, 8:01 PM
Re: bike wobbling
when my bike feels like that the air pressure is WAAAAY low
bubba is offline
post #9 of 12 Old 01-06-2005, 4:37 AM
Re: bike wobbling
Get the bike on some stands and start checking it out. Does front wheel wobble? Does rear wheel wobble? If you get the bike off the suspension, does the rear swingarm wobble, front triple tree? Are the nuts holding your front and rear wheels on torqued down properly? Did you put the spacers back on when you put the tires on after the bearing change?
jaim is offline
post #10 of 12 Old 01-06-2005, 10:08 AM Thread Starter
Ray
Re: bike wobbling
just sent my bike to to my mech.. he give it a check and even strip my rear but couldn't find anything wrong with it..
one thing i don't understand is that why my triple clamp is slanted to one side even dought i didn't crash my bike before.. not even dropped..
anywhere i have a question.. when tightening my rear wheel axis, will the right side of swingarm flex a little?
Ray is offline
post #11 of 12 Old 01-06-2005, 11:16 AM
Re: bike wobbling
Make sure the front rim spacers are on the correct side...it'll will make the front rim not fully centered...some dummy did that to my bike when I didn't have tire changers. But the bike felt fine, nothing I could notice riding but still check.
When you tighten the rear axle the swimgarm will 'compress' or flex...make sure the rear wheel doesn't move out of alignment when tightening.
02FBlade is offline
post #12 of 12 Old 01-06-2005, 11:34 AM Thread Starter
Ray
Re: bike wobbling
thanks that solve some of my worries.. thought my swingarm is gone haha..
will check out my front wheel alignment again.. it happen to me before.. the mech install my front rim out of alignment and i didn't really know.. just kind of noisy as my brake disc is screaming for help..
Ray is offline
RC51 v RC51 v CBR954RR v CBR600RR ccwilli3 Honda FireBlade 53 08-08-2010 4:28 PM
Race report - WERA Beaver Run lfg929 Road Racing: Club / Amateur 8 08-10-2004 1:26 PM
Bike dies. Neighborhood not good. Night falling... zenblader Honda FireBlade 19 08-05-2004 3:08 AM
Performance Bike CBR1000 Spread bwhip Honda FireBlade 1 01-25-2004 12:37 AM
Younger Oil Racing 2003 tigerblade Road Racing: Club / Amateur 1 10-07-2003 2:15 PM
