badly-running 954 - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 01-16-2005, 9:17 PM Thread Starter
badly-running 954
Last week, I managed to foul the 954's plugs while idling it without an airbox or muffler. Or so I thought.
I put new plugs in it today, but it doesn't run any better. No idle. Reduced power. I pulled the plugs after riding about 10 miles, and saw black electrodes. Makes me think it is running rich.
Because the MIL doesn't come on, I want to believe that the ECM is behaving. The shop manual refers to a "fail-safe" mode of fuel injection operation. Could that explain the rich running? BTW, I live at 8400 feet. A default FI map would not assume this elevation.
If the 954 is in fail-safe mode, how do I get it back to normal?
Thanks.
Bob
OldBob is offline
post #2 of 14 Old 01-16-2005, 9:57 PM
CBRBob's Avatar
Re: badly-running 954
Have all the vacuum hoses on? Are all the sensor leads connected. You mentioned having the airbox off. There are sensors on the airbox. Were they off then? Did you connect them when you put it back?
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #3 of 14 Old 01-16-2005, 10:34 PM Thread Starter
Good questions, but I think I have them all covered. Just to be on the safe side, I checked the fault memory. Nothing there.
Bob
OldBob is offline
post #4 of 14 Old 01-16-2005, 11:51 PM
CBRBob's Avatar
Disconnect the battery for 15mins, Reconnect and try it.
CBR Bob
CBRBob is offline
post #5 of 14 Old 01-17-2005, 1:48 PM Thread Starter
Tried that. No change.
I'm starting to suspect the ECM. Unfortunately, the shop manual doesn't give any information on ECM diagnostics; just "try a different ECM". That could be a $500 experiment.
Bob
OldBob is offline
post #6 of 14 Old 01-17-2005, 1:52 PM
You only idled it?
luvtolean is offline
post #7 of 14 Old 01-17-2005, 2:13 PM Thread Starter
Originally Posted by luvtolean
You only idled it?
Yes, but here's the entire story.
I adjusted the valves, and reinstalled the cams. Before buttoning up the motor, I rechecked valve clearances after cranking (with the starter) the motor through a few revolutions.
Everything checked, so I closed the top-end, and attached the wiring. Before installing the air box and muffler, I started the motor just to make sure I had connected everything. It started right up and idled for a few minutes before dying.
When I pulled the plugs, they were wet. I then spayed contact cleaner on them, and wiped them dry.
After reinstalling the plugs, muffler, airbox, hoses and sensors, I started the bike, and rode it (about 5 miles) almost immediately. It ran poorly, and would not idle.
I then replaced the plugs because I thought the old ones were beyond salvaging. Same symptoms. The bike still ran poorly.
Because I had idled the bike without the airbox and its sensors, the IAT and MAP codes (9 blinks and 1 blink, respectively) were stored. I cleared the memory, reconnected both sensors and the MAP's vacuum hose. Same symptoms.
I checked the fault memory, but nothing had stored since I cleared it.
I disconnected the battery for an hour or so. Same symptoms.
Bob
OldBob is offline
post #8 of 14 Old 01-17-2005, 3:57 PM
CBRBob's Avatar
cams indexed wrong?
CBR Bob
CBRBob is offline
post #9 of 14 Old 01-17-2005, 4:32 PM Thread Starter
cams indexed wrong?
No, I was pretty careful with that. This was not my first time to pull the cams.
Any idea what I can expect to pay for an ECM?
Bob
OldBob is offline
post #10 of 14 Old 01-17-2005, 6:53 PM Thread Starter
Open mouth. Insert foot.
The inlet cam was retarded by one tooth. Now I'll re-index the cams, and see if it runs better.
CBRBob: Thanks for your help.
Bob
OldBob is offline
post #11 of 14 Old 01-17-2005, 8:13 PM
CBRBob's Avatar
No problem, your bike was retarded, not you. You asked for help.
CBR Bob
CBRBob is offline
post #12 of 14 Old 01-17-2005, 8:15 PM
cbr99xx's Avatar
Quoted: 27 Post(s)
Reputation Power: 27
Life always looks better through bugs on a face shield.
cbr99xx is offline
post #13 of 14 Old 01-17-2005, 9:25 PM
soon2b954's Avatar
Damn, this guy is pretty good!!
Look, lean, believe!!
soon2b954 is offline
post #14 of 14 Old 01-17-2005, 10:34 PM Thread Starter
Success!!
After I advanced its inlet cam one tooth, the 954 runs like a new bike. I had no idea the motor was that sensitive to cam timing.
I think there's a "knowledge base" entry buried somewhere in this thread.
Bob
OldBob is offline
Info on a 929 / 954 frame and motor differences jcrojas Honda FireBlade 29 01-05-2013 12:54 PM
954 vs. New '04 R1 Mako Honda FireBlade 18 07-16-2005 2:11 PM
Anybody running a 15/41 sprocket combo on their 954? HyrePower Honda FireBlade 10 06-29-2004 5:20 PM
CBR1000RR vs 954 dilema StuUK Honda FireBlade 4 04-20-2004 8:42 AM
Well, the 954 is back up and running! K9inAZ Honda FireBlade 4 12-24-2003 12:41 PM
