Idle question - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 01-17-2005, 1:07 AM Thread Starter
Idle question
I have my idle set at 1200 rpm. When I come to stops during riding, it varies between 1200 and 1450 rpm. What would cause this? "Clueless in Tucson" Not a huge big deal, but disconcerting nonetheless.
Bacchus is offline
post #2 of 10 Old 01-17-2005, 1:28 AM
CBRBob's Avatar
Re: Idle question
Always? Cold/hot? Build up under the throttle plates? Clean that off, sometimes it makes them stick just ever so slightly on closed throttle.
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #3 of 10 Old 01-17-2005, 2:27 AM
Re: Idle question
i always thought it was normal for it to vary around .250 rpm since it does the same thing on my 954 and my mates r1
SouLJahz is offline
post #4 of 10 Old 01-17-2005, 2:43 AM
Re: Idle question
Vacuum leak? Valves need checked? Spark plugs clean?
dattaway is offline
post #5 of 10 Old 01-17-2005, 6:08 AM
Re: Idle question
I'll take vacuum leak for $200 Bob.
jaim is offline
post #6 of 10 Old 01-17-2005, 11:44 AM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: Idle question
How many miles on your bike? Depending, it might need a starter valve synch.
Red Rider is offline
post #7 of 10 Old 01-17-2005, 11:49 AM
Re: Idle question
Yeah, you could get the synch checked.
These bikes are tuned pretty aggressive though, it's probably just the lope of the cams, and the engine management trying to keep up.
luvtolean is offline
post #8 of 10 Old 01-17-2005, 11:58 AM
Re: Idle question
did you take your hand off the throttle
bubba is offline
post #9 of 10 Old 01-17-2005, 12:00 PM
sheepofblue's Avatar
Reputation Power: 48
Re: Idle question
Not sure the miles or setup, but on a car the most common causes are dirty injectors, vacuum leak or worn timing chain.
Must obey the sheep dog
sheepofblue is offline
post #10 of 10 Old 01-17-2005, 4:01 PM
CBRBob's Avatar
Re: Idle question
Harley Parkinsons disease is suspect?
CBR Bob
CBRBob is offline
Question ND4SPD Politics 22 10-21-2004 7:05 PM
Lumpy idle JWHT Honda FireBlade 9 07-26-2004 7:49 PM
Stainless v. rubber - a brake line question Chain General Discussion 8 04-26-2004 5:57 AM
900rr rear seat question. WantaHonda Honda FireBlade 1 04-22-2004 12:39 PM
Question about Exhaust Clamp ronniej Honda FireBlade 3 01-23-2004 1:36 AM
