954 clutch problems? - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 01-31-2005, 6:09 PM Thread Starter
I have a 03 954, when im riding @ around 3000rpm and rapidly roll the throttle the bike pulls for a split second and then it stops pulling and the engine just revs,, could that be the clutch? if so, how can my clutch go out when i just bought a new ebc clutch kit about 2mo ago? I have been trying to learn how to wheelie by using the clutch could that be the problem? The bike is rideable but i cant roll the throttle fast or else it does that, i have to roll the throttle smoothly so it can pull.
hugocbr954 is offline
post #2 of 9 Old 01-31-2005, 6:36 PM
Re: 954 clutch problems?
Chain is offline
post #3 of 9 Old 01-31-2005, 6:51 PM
Who put it in? Did they soak the plates? Was it a dealer, you? Did you replace the springs & ALL plates?
I wanna say not every plate is exactly the same...the last or first depending on your view might be a touch different/thicker/thinner. My teammate has a similar problem on his 929 and I remember him rambling about putting in the plates wrong?
02FBlade is offline
post #4 of 9 Old 01-31-2005, 6:54 PM
Sounds more like it's popping out of gear. Very common on CBRs that are abused with stunting.
BDA116 is offline
post #5 of 9 Old 01-31-2005, 7:50 PM
Sponsor
SilverBullet's Avatar
Reputation Power: 22
Slipping, but BANNED!
EBC...should of got OEM by the way to the rest of you!
SilverBullet is offline
post #6 of 9 Old 01-31-2005, 9:00 PM
pay the extra for OEM, and get the barnett springs.
Or go lock-up like I did and never have that problem again
sonicsbomb is offline
post #7 of 9 Old 01-31-2005, 9:44 PM
If I recall, the inside friction plate has a larger inside diameter to fit over the jutter spring. If it's the wrong plate and it's pressed up against the spring I could see it cause slipping. Make sure you have enough play in the cable so the clutch is fully engaged. It's possible that it's worn out alredy if you've been slipping the clutch at high rpm trying to do wheelies. But I've had the same clutch plates in both my engines (18,000+ street miles, three years of road racing, and 4 or 5 trips to the drag strip) and I haven't had any problems.
Cowboy is offline
post #8 of 9 Old 02-01-2005, 6:14 PM
crazycuRRie's Avatar
Send a message via MSN to crazycuRRie
Ive used several diffrent clutch combinations when i was racing my 954. When i was all finished I ended right back with the OEM Friction and Steel Plates with Barnett Springs... And yes Clutching your wheelies will wear out your clutch
WSMC 954
Sponsor: Mach 1,Chicken Hawk Racing, LP USA, Suzuki Motor Corp.
crazycuRRie is offline
post #9 of 9 Old 02-04-2005, 5:05 PM
That's clutch slippage, plain and simple. If you just put the plates in, then yeah, you did it wrong. Practicing wheelies will damage your clutch basket more than anything, shouldn't do TOO much to the plates. You haven't burnt them out yet. Did you use all of the friction plates? If so, I'll bet money you replaced the 2 "different" oem friction plates and the front and back of the stack. The one at the very back (as already said) is a different diameter. The EBC kit just comes with all the discs the same size. That EBC disc is covering and rubbing the judder springs.
Simple fix. Open it all back up and replace the very front and very back friction plates with the OEM plates. The ones in between can remain EBC if you so choose. And yes, the stock plates are about as good as you'll get.
someoneandhis929 is offline
954 clutch rogerjt General Discussion 16 07-15-2016 12:08 AM
Is the 954 plagued with problems ashkicker Honda FireBlade 71 05-06-2008 8:36 PM
Clutch Problems??? goforitifudare Honda FireBlade 3 09-14-2004 9:02 PM
Clutch fluid leak on my 954???? Hondaman Honda FireBlade 5 08-25-2004 3:58 PM
1000rr Clutch Problems? Performance? hiside Honda FireBlade 10 03-15-2004 10:42 PM
