954 Valve Check Question - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 03-20-2005, 8:38 AM Thread Starter
One of the last projects I want to get done before spring rides and track days is to check the valves.
The bike currently has 13,000 miles and while I don't hear a lot of clacking around coming from the cyl head, I just want to make sure everything is good to go.
So here's the issue.
The service manual calls for a special tool to hold the CCT all the way in after you are supposed to crank down the CCT.
I'm wondering how important that tool is and if I really need to use something like that, then is there any way to fabricate a replacement as I don't want to wait /spend for the Honda tool.
I figure there has got to be a work aound for this.
'Lil help?
Voodoo954 is offline
post #2 of 8 Old 03-20-2005, 8:41 AM
Re: 954 Valve Check Question
The tool isn't listed in the required tools for the 929 at least:
https://www.fireblades.org/forums/showthread.php?t=11217
ConqSoft is offline
post #3 of 8 Old 03-20-2005, 10:11 AM Thread Starter
Yeah, I saw your thread in the KB.
They've got to be pretty similar, huh? (929 & 954)
Thanks, I'll give it a shot.
post #4 of 8 Old 03-20-2005, 11:39 AM
In post #5 pic You're a Freak W/all those extra extremities
KJ's RR is offline
post #5 of 8 Old 03-20-2005, 11:41 AM
Talk to Joel. It's his article.
ConqSoft is offline
post #6 of 8 Old 03-20-2005, 10:47 PM
I just Checked Mine Two Week's Ago ( 20,000 km ) Had two Tight one's I found the wireing harness a bit of a Pain to get aroung the cross-member at the top of the frame I also had a *Throttle body Sincronization * done after it was Back Togethier !!
Machinist is offline
post #7 of 8 Old 03-21-2005, 1:02 AM
You only need the tool if you have to adjust the valves.
I fabricated mine with tin snips and an old electrical box. The service manual has good instructions for making that little tool.
Joel is offline
post #8 of 8 Old 03-22-2005, 10:19 PM Thread Starter
excrement!!
thanks for the info
Pair valve mod for 954 larddog954 Honda FireBlade 10 11-22-2006 8:37 PM
954 ignition question sonicsbomb Honda FireBlade 1 02-04-2005 8:13 AM
Question about the 954? Bikerbabe954 Honda FireBlade 3 05-31-2004 4:47 PM
954 929 fork question LNSPLTRS Honda FireBlade 1 08-22-2003 8:20 PM
929 will not start after valve check Seeker Honda FireBlade 18 08-20-2003 10:20 AM
