penske remote reservoir - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 03-21-2005, 1:49 PM Thread Starter
anyone have pics of (or describe) where they mounted a remote reservoir on a 954? also any mods necessary to make it fit? want to make sure I mount it in a good and safe place. thanks
kc954 is offline
post #2 of 12 Old 03-21-2005, 3:00 PM
HondaGalToo's Avatar
Reputation Power: 32
Re: penske remote reservoir
On my 929 I mounted the reservoir on one of the bolts the passenger peg would screw into, since I removed them. I did it on the side opposite the exhaust. HondaGal did the same on her 954, but she used a bracket of some sort she had laying around to ensure that it wouldn't come in contact with the rear hugger while hitting bumps. The bracket kept in just a bit outside of the subframe, rather than inline with it or slightly inside of it. There seems to be a bit less clearance with the 954 than the 929.
HondaGalToo is offline
post #3 of 12 Old 03-21-2005, 3:14 PM
I think he's talking about the actual shock reservoir, not a preload adjuster.
Most guys with penske's fix it to the subframe somehow. I suggest putting it under there as it'll be fairly well protected in a crash.
ccwilli3 is offline
post #4 of 12 Old 03-21-2005, 3:24 PM
Oh, ok, never mind, then! Since I have an Ohlins, I didn't realize Penske had another part that needed to be mounted somewhere.
post #5 of 12 Old 03-21-2005, 3:39 PM Thread Starter
yep its the reservoir, not just a preload adjuster. the only place to really secure it is the subframe, I'm just afraid of it making contact with the swingarm/undertail on big bumps. It sure doesn't seem to leave much room
kc954 is offline
post #6 of 12 Old 03-21-2005, 4:12 PM
Do you have the aluminum reservoir mount? The mount right up to the subframe (staggered off of the rear footpeg mount).
abtech is offline
post #7 of 12 Old 03-21-2005, 4:58 PM Thread Starter
I have what penske supplied, two big hose clamps and two rubber cushions that go between reservoir and subframe. It seems like it would fit ok by the rear footpeg mount, but the supplied mounting parts wouldn't do the trick without cutting into my trunk which I would really like to avoid.
kc954 is offline
post #8 of 12 Old 03-21-2005, 5:01 PM
I think (could be wrong) that abtech is talking about the "one off" penske reservoir adapters a few RC51 guys got for their penskes made by one "dan kyle"...
I had one for my RC and it was sweet! Didn't want to hastle with the reservoir on my 600RR, so I got an ohlins.
ccwilli3 is offline
post #9 of 12 Old 03-21-2005, 5:03 PM Thread Starter
****. I just had my forks done by DK and I asked him a few setup questions, and when I said I'm installing a penske, all he said was "don't" lol. If that was something he has I'd sure be interested.
kc954 is offline
post #10 of 12 Old 03-21-2005, 5:05 PM
He doesn't make them anymore, and when asked, he showed no interest in them...
ccwilli3 is offline
post #11 of 12 Old 03-21-2005, 6:02 PM
BK_
Here ya go.
Use a steering damper fork leg clamp to hold the reservoir. Bolt it into the M8 hole shown in the attached drawing. Bolt the reservoir onto the passenger footpeg mount on the left hand side.
Reservoir Mount Drawing
Baketech will knock you one up in necxt to no time.
BK_ is offline
post #12 of 12 Old 03-21-2005, 10:10 PM Thread Starter
I may be ridin the short bus but I don't know what the hell that was
kc954 is offline
Ride Hight With Penske Shock? 954spider Honda FireBlade 26 03-13-2006 4:39 PM
Remote Desktop Connection firedawgon929 Off-Topic 4 12-21-2004 12:23 PM
HRC Reservoir Covers EmDee General Discussion 13 10-08-2004 10:26 AM
Custom 954 brake reservoir EDDIE110171 Honda FireBlade 4 10-02-2004 11:30 AM
