954 Questions: engine cut-out, low-speed gear changes - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 03-21-2005, 1:49 PM Thread Starter
I recently bought an RR2 and it's a truly fabulous ride -- a great, fun complement to the VFR800 I use for daily transport. There are two things I want to check out with other owners:
1/ On two occasions (in about 800 miles of riding), the engine has cut out while in neutral. On both occasions this was on coming to a stop after riding for a while. The bike started up again immediately and with no problems. Any ideas as to what might be causing this?
2/ Gearchanges to/from first and second seem very clunky. Is this me being hamfisted, a common problem on these bikes or indicative of a problem? The 'box is slick and sweet once things are underway.
Cheers all,
Peter
tofty is offline
post #2 of 4 Old 03-21-2005, 2:08 PM
Re: 954 Questions: engine cut-out, low-speed gear changes
Welcome to the .org!
If you adjust the idle rpm upwards a bit , that should take care of that problem. And as for shifting, I find it to be smoother to not upshift with the clutch. just load the gearshift a bit with your foot, and momentarily drop the revs.
Nice choice of bikes!
CBRVFR is offline
post #3 of 4 Old 03-21-2005, 2:58 PM
Does it have a power commander? mine went bad!
6th Gear is offline
post #4 of 4 Old 03-21-2005, 3:06 PM Thread Starter
No power commander -- it's a pretty standard bike.
I'll tweak the idle speed up slightly as suggested, and try clutchless shifting.
Thanks guys!
tofty is offline
954 Engine Swap Info Latebraking Honda FireBlade 12 11-26-2007 5:46 PM
954 engine modifications n0xiu1 Honda FireBlade 17 06-18-2004 12:29 PM
954 Engine...What Will I Be Missing? Sprusgoose Honda FireBlade 5 05-22-2004 10:43 AM
has anyone bolted a 954 engine onto a 929 guru929 Honda FireBlade 2 05-20-2004 9:54 PM
954 engine question chrisbratton22 Honda FireBlade 1 03-15-2004 12:39 PM
