954 rich at startup - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 05-10-2005, 4:20 AM Thread Starter
Reputation Power: 15
954 rich at startup
My 954(stock exhaust/filter) is always running real rich at startup. If I start it cold it runs rough and smells rich.
yesterday I was doing trackday, and even the engine moderate warm at previous session, it always smells rich after starting. When it runs for couple of seconds it's fine.
Is this common?
Jaket
JakeT is offline
post #2 of 11 Old 05-10-2005, 5:23 AM
Re: 954 rich at startup
first id check your air filter and then the condition of your spark plugs, see if they are really dark from carbon build up since they may not be generating enough spark when cold.
SouLJahz is offline
post #3 of 11 Old 05-10-2005, 7:43 AM Thread Starter
Airfilter is as good as new. Haven't check the plugs yet, they are pretty new.
I think there is enough spark, it starts right up with all four.
JakeT.
JakeT is offline
post #4 of 11 Old 05-10-2005, 7:47 AM
Administrator
Red Rider's Avatar
Reputation Power: 47
Gotta ask...do you have a Power Commander? If so, disconnect it and see if that helps.
Red Rider is offline
post #5 of 11 Old 05-11-2005, 3:02 AM Thread Starter
no, it's stock.
I have commander but haven't installed it yet.
Bike have been crashed, big time.
JakeT is offline
post #6 of 11 Old 05-11-2005, 7:48 AM
i think all FI engines run rich at start up...both my bikes do it and my car also and then lean out at running temp
ozthis is offline
post #7 of 11 Old 05-11-2005, 6:16 PM
My stock 954 does this also. It runs fine after it warms up a bit. I think this is normal best I can tell.
desertfox is offline
post #8 of 11 Old 05-11-2005, 6:20 PM
Yep, it's just the start-up map. It's a computerized "choke".
"Bike have been crashed, big time."
One serious thought though, did it go into a gravel trap or dirt? If so, you need to check the airbox, it's probably full of gravel/stones.
luvtolean is offline
post #9 of 11 Old 05-12-2005, 4:15 AM Thread Starter
thanks, I didn't crash it. Bought it crashed.
And yes I checked the airbox, it had lot of gravel there. Also at the top of the cam cover was lot of gravel, I vacuumed all that stuff out of there, luckily before I removed the plugs
here's how the bike looked when I got it.
here it's now
frame has been measured by professional, it's staight.
JakeT.
JakeT is offline
post #10 of 11 Old 05-12-2005, 3:49 PM
Nice! It looks brand new now. What is that on the cannister? does it work keeping passenger's heels off the pipe?
slowpoke is offline
post #11 of 11 Old 05-13-2005, 1:07 AM Thread Starter
There was dent in the pipe, and I had old carbon fiber canister cover. It just looks better then dent
JakeT is offline
929 or 954?  Should have kept... larddog954 Honda FireBlade 48 01-05-2017 6:00 PM
Info on a 929 / 954 frame and motor differences jcrojas Honda FireBlade 29 01-05-2013 11:54 AM
Opinions of 954 VS. 900/929/1000 ke0kie Honda FireBlade 55 05-01-2006 8:52 PM
954 vs. New '04 R1 Mako Honda FireBlade 18 07-16-2005 1:11 PM
CBR1000RR vs 954 dilema StuUK Honda FireBlade 4 04-20-2004 7:42 AM
