2001 929 won't start - Honda Motorcycles - FireBlades.org
post #1 of 22 Old 05-10-2005, 9:13 PM Thread Starter
Hello I just got a 2001 929rr in a box and put it together. When I try and start it the motor turns over and I have compression. When I do a Spark test there is nothing. The grounds are connected. Anybody have any words of wisdome for me. Thanks
erhunter is offline
post #2 of 22 Old 05-10-2005, 9:24 PM
Re: 2001 929 won't start
bank angle sensor on the nose of the bike, could be upsidown,
Neutral switch
Stand switch
l'timbré is offline
post #3 of 22 Old 05-10-2005, 9:27 PM Thread Starter
what does the back angle sensor look like. If the stand switch was bad would'nt that keep it from turning over.
erhunter is offline
post #4 of 22 Old 05-10-2005, 9:28 PM
What is the last thing you messed with on the bike?
BDA116 is offline
post #5 of 22 Old 05-10-2005, 9:31 PM Thread Starter
The last thing I did was traced all ground wires back to the ECM and made sure that the ground was good. I turns over like it would start if it could get a spark.
erhunter is offline
post #6 of 22 Old 05-10-2005, 9:34 PM
Before it stopped working.
BDA116 is offline
post #7 of 22 Old 05-10-2005, 9:37 PM
It is there
l'timbré is offline
post #8 of 22 Old 05-10-2005, 9:38 PM Thread Starter
I bought it off of ebay and it was in pieces. The only thing togeather was the engine. The wiring harness, frame, wheels, were all seperate.
erhunter is offline
post #9 of 22 Old 05-10-2005, 9:38 PM
He got the bike in parts in a box.
l'timbré is offline
post #10 of 22 Old 05-10-2005, 9:50 PM Thread Starter
I looked and my bank angle sensor is under the front seat mount. Or are there two? I don't have one infront of the bike.
erhunter is offline
post #11 of 22 Old 05-10-2005, 10:29 PM
Yes, the bank angle sensor is under the front seat on the 929.
Do you have a service manual? You can check the wire harness for general questions here: http://www.ronayers.com/fiche/200_03...10&parent=5320
It shows how it should be assembled. Take a look through the rest of the parts fiche for hints.
Maybe start with the main fuse, fuel cutoff relay or the previously mentioned switches. Red stop switch set to run? Kickstand down, bike in neutral? Just go back to basics.
Does the fuel pump prime when the key is turned on? If not, check the fuel pump relay or fuse. Hell, check all the fuses just for kicks.
BDA116 is offline
post #12 of 22 Old 05-10-2005, 10:42 PM Thread Starter
would a bad ecm keep it from getting spark? I am going to get a meter tomorrow and test the peak voltage. Does anbody know where I can get the correct type of meter
erhunter is offline
post #13 of 22 Old 05-10-2005, 10:51 PM
nomad's Avatar
Wyseone had a similar issue (I think) and his problems were due to a bad wiring harness.
Jordan H.
The three most feared words in racing, "Powered by Honda".
nomad is offline
post #14 of 22 Old 05-11-2005, 9:49 PM
Here is what the manual says to look for if you arent getting any spark.
-Faulty Plugs
-Faulty ECM
-Broken or shorted spark plug wire
-Faulty ignition switch
-Faulty ignition pulse generator
-Faulty stop start switch
-Loose or disconnected ignition wires
Because you are getting the motor to turn over (correct?). I can tell you its not the ignition switch or the start stop switch.
MrFurious is offline
post #15 of 22 Old 05-12-2005, 8:31 AM Thread Starter
Hello I checked the wires and they are ok. I am going to try and test the ignition pulse generator today. I get battery voltage at the coil with the ingnition on and the run switch on. When I crank it over the voltage drops to 11-12volts from 14. It does not peak out at 100v like it is supose to.
erhunter is offline
2001 929 Dead Battery Blich Honda FireBlade 7 06-08-2007 5:24 AM
HELP... 929 wont start! sizmtrz Honda FireBlade 7 03-11-2005 9:59 AM
CBR 929 WONT START kalaiz69 Honda FireBlade 0 02-18-2005 9:13 PM
929 won't start. Help! WetShrub Honda FireBlade 23 01-23-2005 12:03 PM
2001 929 Race Wiring lqdadrenaline Honda FireBlade 5 10-03-2004 7:29 PM
