1000RR radial master cylinder on 954RR?? - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 05-24-2005, 6:19 PM Thread Starter
Has anyone put any thought into this or even attempted it??
Not that the 954's braking can even be called into question but a radial master cylinder is the most effecient way to apply force to the calipers. While I'm sure absolute braking power increase are neglible I have a feeling that feel & perhaps bite may be improved & be more usable to average riders.
Also they look classy & are definetley worth some kudos!
So again does anyone know if the 1000RR's master cylinder closely matches the piston size/ares/volume of the 954RR's & if they seem a good match??
Perhaps even the new 600RR's might be a viable option??
King Kenny is offline
post #2 of 13 Old 05-25-2005, 9:26 PM
Re: 1000RR radial master cylinder on 954RR??
The 05 600RR is not a radial MC, they use a conventional design almost if not identical to the F4I
wolley is offline
post #3 of 13 Old 05-30-2005, 5:32 PM Thread Starter
Thanks Wolley.
Surely someone eles has thought of/done this??
post #4 of 13 Old 05-31-2005, 8:12 AM
Jungleboy's Avatar
I just bought a pair of 1000RR Radial calipers off ebay and have lined up a pair of 1000RR forks. I will be mounting these on my 954 using the origional 954 front wheel and 330mm discs with 10mm spacer's between the caliper and brake mounts. To compliment this I will also be adding a brembo 19x20 Radial Master cylinder for what should make a pretty mean set of brakes
2004 1000RR Racebike
www.jungleboyracing.com
Jungleboy is offline
post #5 of 13 Old 10-10-2005, 9:18 PM
Whatever happened with this setup? I'm quite interested.
someoneandhis929 is offline
post #6 of 13 Old 10-11-2005, 12:03 AM
Zeeman's Avatar
Quoted: 4 Post(s)
Reputation Power: 22
that should be pretty awesome. definately have to catch up when you get all that done....
I take it the 1000RR has a 310mm disc?
Z...
You're f%#&king up my Chi...
Zeeman is offline
post #7 of 13 Old 10-11-2005, 12:11 AM
phobiaphobe's Avatar
Reputation Power: 43
Are the rotors the same thickness?
phobiaphobe is offline
post #8 of 13 Old 10-30-2005, 8:56 AM
Jungleboy's Avatar
Yes Im a bit of a procrastinator, but it should be all sorted out very soon, just been a bit preoccupied of late... Ive decided to buy a brand new set of lower legs from honda and match them to my 954 cartridges and out/upper tubes. Also just aquired a PT 19x20 Billet Radial Master Cylinder so it shouldnt be long till its all up and running
PT1.jpg‎   PT2.jpg‎
post #9 of 13 Old 10-30-2005, 9:04 AM
Jungleboy's Avatar
Z...
Yeah for sure, Ill keep you posted!
yeah the 04/05 1000RR has 310mm but I think they have gone up to 320 on the 06 1000RR
The 1000RR Discs are 0.5mm thicker but it is of no real consequence
post #10 of 13 Old 10-30-2005, 11:14 AM
CBR929RE's Avatar
Reputation Power: 39
if the 1000RR has 310s and the 954 has 330s wouldn't you need 20mm spacers not 10?
CBR929RE is offline
post #11 of 13 Old 10-30-2005, 11:32 AM
You need to think in terms of a radius as it's the distance from the axle.
310/2 = 155mm
330/2 = 165mm
165-155 = 10mm
luvtolean is offline
post #12 of 13 Old 10-30-2005, 11:35 AM
CBR929RE's Avatar
310/2 = 155mm
330/2 = 165mm
165-155 = 10mm
I was thinking that but wasn't sure if that was the right idea or not.
CBR929RE is offline
post #13 of 13 Old 04-30-2006, 4:52 AM
Jungleboy's Avatar
Well my project is half completed, Ill have my Goodridge lines this week and then Ill mount my PT billett radial master cylinder
JB954RR.JPG‎   1000RRCaliper3.JPG‎
Brembo Brake Master Cylinder and SS lines SLODUCK For Sale 1 05-06-2005 9:41 PM
Please help identify this master cylinder!! hoagie General Discussion 13 01-01-2005 1:53 PM
Front brake master tech cylinder question G-Force Junkie General Discussion 13 11-24-2004 1:59 AM
Brembo front master cylinder 425954guy Honda FireBlade 9 11-04-2004 12:01 PM
Question: 954 vs. 929 Front Master Cylinder Chrome Dome Honda FireBlade 5 08-29-2004 2:14 PM
