Switching rims on a 93 - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 05-15-2003, 7:52 AM Thread Starter
Re: Switching rims on a 93
I am looking to get rid of my front 16 inch rim on my 93 CBR 900rr, has anyone done this and what do I need to do to make it a 17 inch rim....need details!!!! THX
jking206 is offline
post #2 of 6 Old 05-17-2003, 11:14 PM
I'm pretty sure the front rims are interchangable with the 17 inch f2 rim. I think you'll have to use the rotors from the 900 though. Someone whos actually done it could give ya some more info though
DocWhiplash is offline
post #3 of 6 Old 06-07-2003, 4:53 AM
i was gonna put a 17' on the front of my 95 RR, then, after some research, i found out that it slows the steering way down, and makes tankslappers almost commonplace.... so, needless to say, i decided against it
dingoRR is offline
post #4 of 6 Old 06-07-2003, 6:15 AM
The 17' rim is the way to go. I did it on my 99 about 6 months ago and it makes it a so much easier to find good tires. The f2 rims should bolt right up, but I'd do a little research. As for the steering, the fork tubes have to be raised to compensate for the taller tire. I raised mine 13mm and the bike is very stable. You will notice a bigger change when you go to a 120 size front instead of the 130 that is stock on the 900.
I've got some info lying around the house from when I switched mine over. If I can find it, I'll send it to you.
Pater is offline
post #5 of 6 Old 06-07-2003, 6:38 AM
Check that!! *F2 rims WILL NOT bolt up to the 900. *The f3 rims should. *Here's more info than you will never need. * Scroll a third of the way down and you'll find the conversion numbers.
rrzone.com
Pater is offline
post #6 of 6 Old 06-09-2003, 10:14 PM Thread Starter
Thanks so much I appreciate it!!!!!!!!!!!!!!!!!!!!!!!
jking206 is offline
Finally got my rims back!!! 3cRider Honda FireBlade 17 11-28-2003 6:16 PM
Straightened rims ND4SPD Honda FireBlade 6 11-27-2003 2:04 AM
where and how much to chrome rims? trey Honda FireBlade 11 11-07-2003 3:19 PM
rims that will fit Rigger Honda FireBlade 2 07-01-2003 11:03 AM
