929 CUTS OUT HELP PLEASE!!!!!! - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 07-29-2005, 1:28 PM Thread Starter
Hi all,i'm new to this site and it looks like you all know your stuff so i'm hoping you could help.....my 929 cuts out sometimes for no reason,especially after riding fast and than changing down gears it cuts out while clutch is in,doesn't happen often but is still a worry,it is also not so smooth in first gear on pull away,i was thinking maybe the plugs?........hope someone can help...............A BIG HELLO TO ALL FROM LONDON U.K
player80978 is offline
post #2 of 12 Old 07-29-2005, 1:46 PM
ND4SPD's Avatar
Reputation Power: 50
Re: 929 CUTS OUT HELP PLEASE!!!!!!
Check your plugs, air filter and fuel filter.
ND4SPD is offline
post #3 of 12 Old 07-29-2005, 2:01 PM
It could also be an electrical connector or ground coming loose. When you come off the gas or pull the clutch that quick weight / inertia transfer may be knocking it enough to cause a quick power cut.
My F3 racebike started doing that once many moons ago, and I took apart each connector and re-seated it, as well as tightening all the ground bolts.
It didn't do that again.
BDA116 is offline
post #4 of 12 Old 07-29-2005, 2:02 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
First question I always ask...does it have a Power Commander?
Red Rider is offline
post #5 of 12 Old 07-29-2005, 2:12 PM Thread Starter
no power commander and no dyno kit
post #6 of 12 Old 07-29-2005, 3:01 PM
Administrator
Red Rider's Avatar
Hmmm...how is it cutting out? Does it completely shut off, or does it sputter like it's running out of fuel?
post #7 of 12 Old 07-30-2005, 6:59 AM Thread Starter
it totally cuts out
post #8 of 12 Old 07-31-2005, 6:56 PM
Originally Posted by player80978
it totally cuts out
Hi Player80978,
I haven't had any experience like this with my 929, but I do recall reading a thread about this where one of the guys had his bike cutting out over bumps and tracked the problem down to a loose battery connection.
Your symptoms are similar - pull the clutch in and the engine cuts, when you dump the clutch the bike bump starts itself again...
Probably worth having a look at that before you start pulling everything else apart anyway.
Cheers, Spanky.
Spanky is offline
post #9 of 12 Old 08-01-2005, 12:08 PM
My 929 has died on me more times this year than I care to mention.
Two easy checks:
1. Check the battery connections.
2. Check the fuel vacuum line (it might be pinched in the rear shock)
Yours sounds like the first one.
-Rob.
SpikedLemon is offline
post #10 of 12 Old 08-01-2005, 12:55 PM Thread Starter
Thanks everyone i'll check it out
post #11 of 12 Old 08-01-2005, 3:09 PM
Reputation Power: 15
Like what has said above.. check the battery connections. My wife's bike was doing a similar thing, tightened the connections repeatedly and they were tight.... ended up the bolt for the battery cable was 2 threads too long so the cable would wiggle a bit. Cut 2 threads off the bolt and never another problem. (Thanks to the local shop for giving me this addded enterainment )
Andrew1400 is offline
post #12 of 12 Old 08-01-2005, 4:26 PM
Check the sidestand switch. This has caused a lot more problems than it has ever solved. Good luck.
knowlimits is offline
929 Stock brake pad help please? KiwiBlader Honda FireBlade 1 05-11-2005 2:57 AM
Engine compression problem, please help me out! JinMTVT Honda FireBlade 2 05-09-2005 10:14 PM
Need help with 01 929, please :-( nickxx4360 Honda FireBlade 3 04-23-2005 10:33 PM
all you car mecanics out ther help please DanDRRMan Off-Topic 15 12-26-2003 12:27 PM
Need Help, Please, Please, Please BushrodW Honda FireBlade 9 06-20-2003 4:24 PM
