954 uneven break pad wear - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 08-28-2005, 5:01 AM Thread Starter
Reputation Power: 15
I was checking my brake pads and notice the left side front pads are almoust gone, also little uneven wear. Right side has lot of pads left.
I mean both pads are worn down at the left side of the bike.
Is this common? I have stock brake lines. They are still original pads, ~15thousand km on them. Lot of trackdays and hard driving, so I quess it's not that bad.
Jaket.
JakeT is offline
post #2 of 11 Old 08-28-2005, 5:31 PM
Re: 954 uneven break pad wear
They do tend to wear unevenly. It is compounded by how clean the calipers are kept, as they get grunged up, one side can tend to drag more. Pull the pads out and clean the hell out of the piston areas, and make sure the pad retaining pins are not grooved or beat up as the pads can hang up on them. I only got 8k miles out of my first set (whatever that is in km)
G-Force Junkie is offline
post #3 of 11 Old 08-28-2005, 6:58 PM
also try bleeding the brakes to see if that makes any difference.
SouLJahz is offline
post #4 of 11 Old 08-28-2005, 7:27 PM
NinerPilot's Avatar
Reputation Power: 25
I wouldnt reccomend bleeding the lines if you are not sure of what you are doing. IF there were any air in the lines, it would not affect pad wear, just overall brake performance. There is a better chance of unleashing more problems by bleeding the brakes if he is unfamiliar with them.
Chris
NinerPilot is offline
post #5 of 11 Old 08-28-2005, 8:39 PM
wouldnt having air down one of the lines cause that side of the brake system to not brake as hard as the other?
SouLJahz is offline
post #6 of 11 Old 08-28-2005, 8:44 PM
No, all the lines are connected to one master cylinder, when the system is pressurised, both sides will self balance the same pressure. The only thing that could result in what your talking about would be an actual obstruction or kink in one line.
post #7 of 11 Old 08-28-2005, 8:57 PM
cool makes sense.
also a slightly warped rotor can cause uneven wear as well, but im sure u'd notice some vibrating while you are braking
SouLJahz is offline
post #8 of 11 Old 08-29-2005, 1:18 AM Thread Starter
yep, I'm pretty familiar with the bleeding and changing fluids and all. I have to change the fluid anyways so I check that too.
But it makes sense the pressure gets equal. Well new pads anyways and clean them all.
JT
10miles is ~16km, so 8000miles is prettu close to what my pads lasted.
JakeT is offline
post #9 of 11 Old 08-29-2005, 1:46 AM
NinerPilot's Avatar
When you clean them:
Loosen the pins before you take the calipers off. Then pump the brakes until the pads touch. Remove the pads, and using an old toothbrush and some cleaner, clean all around the piston and inside the caliper.
post #10 of 11 Old 08-29-2005, 3:14 AM Thread Starter
rant: david silver sells those pads for ~25euros including tax. In here Finland they are 40euros per disk...
JakeT is offline
post #11 of 11 Old 08-03-2007, 5:18 PM
I had the same problem at 11k miles on my RR4. The left pads were more worn than the right, and also the left-left pad was worn unevenly. Nothing seemd jammed, but I'd lost braking efficiency. Which prompted the change of pads. Once I'd taken them off, I realised I'd been fooling myself about the state of the brakes. All but one of the wear groves were clearly visible, but the last was two thirds completely erased.
dadneo is offline
Uneven tire wear 1pcbr General Discussion 39 05-19-2006 11:20 AM
954 Brake Pad Part # 41ants Honda FireBlade 0 06-22-2004 1:14 PM
954 brake pad replacement magic Honda FireBlade 2 05-05-2004 7:40 PM
954 dyno break in experience Zeeman Honda FireBlade 67 04-25-2004 1:13 AM
Brake pad wear TraumaOne Honda FireBlade 6 09-12-2003 7:12 AM
