Bad Mating Surface? - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 08-29-2005, 12:03 AM Thread Starter
Bad Mating Surface?
So I had to have the lower crank case welded because it chipped off when I dropped the bike on the left side and the area near the weld appears to be leaking ever so slightly.
Honda uses a paper gasket and since I'll be replacing the stator cover AGAIN (it cracked again on a REALLY light drop) is there any way I can use a different gasket material that may help seal this area better? What about a liquid gasket?
Also, Whats the best way to clean off the old gasket? I don't want to dammage the surface.... I have seen 2" discs for die grinders made with little rubber knobbies for cleaning gaskets but is there any easier way? I don't have access to a die grinder.
Adam
atr911 is offline
post #2 of 14 Old 08-29-2005, 12:07 AM
Re: Bad Mating Surface?
Razor blade is what I normally use. Just be careful.
You could try a non-hardening gasket maker/sealer. Yamabond is the old standby but now Permatex has some similar stuff available at your local parts store, "Motoseal".
http://www.permatex.com/motorcycle/P...&item_no=29132
luvtolean is offline
post #3 of 14 Old 08-29-2005, 12:22 AM
I think 40-60 grit sandpaper would be a bad "mating" surface.
Bacchus is offline
post #4 of 14 Old 08-29-2005, 12:32 AM Thread Starter
lol I though rug burn was bad!
We sell that motoseal stuff at my shop, I'll have to grab some. Can you goop it on?
Adam
atr911 is offline
post #5 of 14 Old 08-29-2005, 12:47 AM
Don't get too crazy with it, but it's pretty inert stuff.
post #6 of 14 Old 08-29-2005, 12:47 AM
First off, get the mating surfaces as level as you can. Sure a slow drop can crack it, but its even more likely if the repair is high, and the cover is deflected and put under tension whenyou tighten down the bolts. I would rather the mating surfaces be .020" low that .010" high. Like LTL said, use whats called a semi-drying sealer. Yamabond is good, as is Three Bond 1104. It is all that is used for sealing cases on 2 strokes and the like. Clean all surfaces with laquor thinner before sealing.
G-Force Junkie is offline
post #7 of 14 Old 08-29-2005, 11:13 AM
I've heard that the gasket for the stator is not only there for a seal, but also spacing. If you decide to use a gasket maker of some sort, I'd definately use the gasket as well to maintain spacing. Maybe goup it with the gasket maker?
Jake is offline
post #8 of 14 Old 08-30-2005, 1:21 AM
Honda used a small dab of sealent when the put the cover on at the factory, but only at the two spots where the cases meet. Put as little as you can on it and still have it squeeze a tiny bit out. Any more than that, and the excess is squeezing inside as well. I would run a small bead, the size of a string of spegettii, on both sides and bolt it up with the gasket.
post #9 of 14 Old 08-30-2005, 7:58 AM
honda makes a great product called hondabond. You can get it at any honda auto/motorcycle or acura dealer. Stuff works like a champ
ozthis is offline
post #10 of 14 Old 08-31-2005, 3:15 PM
I am going through the same repair, I had a very light leak at the bottom of the cover, I pulled it and applied HondaBond to the gasket with a putty knife (which I also used to scrape off the old gasket, followed by a light scrubbing with steel wool)
Fixed the leak, but I was lazy and just tightened up the bolts around the cover by feel, I'll be doing the repair again, this time replacing the cover, as I cracked it when tightening the bolts. Must've been slightly over the 12Nm - 9ft/lb torque spec So, be careful.
Live and learn..
rodan is offline
post #11 of 14 Old 08-31-2005, 3:21 PM Thread Starter
Rodan, if you're spending the money on a new cover BUY AFTERMARKET! They're WAY more durable and the last thing you need is to crack the engine case like I've done. Turns a nightmare of a minor drop into a HELL or a engine swap (worse case scenerio).
www.circuit1.com OR Factory Pro OR Billet Tech
Adam
atr911 is offline
post #12 of 14 Old 08-31-2005, 6:30 PM
Atr911:
Thanks for the link. I am gonna take your advice and order, I think, the Circuit 1 cover.
I have to call them tomorrow (web guy gone today and their page isn't accepting my CCard) So, in the meantime, anyone have one of these and can vouch for it?
It's gotta beat the hell out of the flimsy Honda Cover (although at over three times the price) and looks like you'd be able to ride away after a low speed crash on that side, which is near impossible with the stocker (hope I never have to test it)
Thanks again.
rodan is offline
post #13 of 14 Old 08-31-2005, 6:31 PM
phobiaphobe's Avatar
Reputation Power: 43
I tried on a trampoline once but it was really hard to get a proper rhythm going.
phobiaphobe is offline
post #14 of 14 Old 09-02-2005, 3:56 PM
Circuit 1 : 954 Alternator Cover
Received the cover today and installed it.
Posted some pics of the cover and install - Here:
https://www.fireblades.org/gallery/br...00&userid=5880
rodan is offline
how bad is a bad charging system? Fireblade-RR Honda FireBlade 9 06-28-2008 5:44 PM
Bad Map Or Bad pcIII bjay51d Honda FireBlade 11 06-09-2005 2:22 PM
Having a bad day, a bad month, a bad year? Bacchus Off-Topic 4 09-03-2004 3:34 PM
bad idle? not so bad MarkN929RR Honda FireBlade 6 10-31-2003 7:24 PM
Good, bad, bad day today. stegen Off-Topic 15 06-20-2003 3:39 AM
