Thermostat? 1000RR 2004 - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 08-29-2005, 1:52 PM Thread Starter
Usually when I'm riding once the bike gets to 180 degrees it stays there (+/- 5) unless traffic where once the fan goes on (around 220) it was able to keep the temp from 225 to 180. Now, even in cold weather it seems like my bike is running a lot hotter and the fan can hardly keep up in light traffic. I think its the thermostat because when I start the bike and let it warm up to 150 before I take off the temp will slowly rise to 195 and then suddenly drop to 175 and then rise slowly back up to 190. Is the thermostat "sticking" and a signal that itís about to completely crap the bed?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p></o:p>
<o:p></o:p>
Thanks for any help...<o:p></o:p>
<o:p></o:p>
PS: I thought maybe the radiator was dirty so i took an air hose to it. It helped a little but not much.<o:p></o:p>
<o:p></o:p>
kewlkid is offline
post #2 of 4 Old 08-29-2005, 9:39 PM
Re: Thermostat? 1000RR 2004
Mine does that too, when I start the first time it gets warmer before it cools back down. I always thought of it as the thermostat opening, at startup. Like once it opens the temp will still rise until the cooler fliuds get near the sensor.
Smitty929RR is offline
post #3 of 4 Old 09-01-2005, 8:50 AM
vma
Mine 2004 does the same thing. First it gets quite hot and then it cools down. If I remember correctly, it didnt do that when the bike was new
In the city, it gets really hot. Fan is spinning all the time and can hardly keep up with the heat.
vma is offline
post #4 of 4 Old 09-01-2005, 9:01 AM
ND4SPD's Avatar
Reputation Power: 50
That drop in temp after the initial warmup is the thermostat opening and letting cooler coolant in from the radiator. Both of my bikes that have had digital temp gauges have done that...it's normal. Honda's tend to run hotter than most other bikes...fan will come on around 220 and might go as high as 225-230. I wouldn't be worried until it went up above 230.
For piece of mind, with a completely cold engine, put your bike on a center stand or have a friend hold it straight up/down and check the coolant level in your reservoir. You will see two lines on it. The lower one being the minimum level it should be when the engine is cold. If you're somewhere inbetween the two lines it's pretty much ideal, IMO.
ND4SPD is offline
Performance Mods 2004 1000RR Blade a1120028 Australia 20 10-25-2007 4:46 AM
1000rr Service Manual- 2004-05 oldgoat For Sale 0 08-13-2005 6:14 AM
What is a 2004 1000rr worth? waytooslow Honda FireBlade 6 02-22-2005 10:42 PM
White 2004/2005 1000RR CBRSP2 Honda FireBlade 27 11-17-2004 3:52 AM
thermostat removal joerace Honda FireBlade 2 08-14-2003 12:32 AM
