quick sprocket question - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 08-31-2005, 7:21 PM Thread Starter
Is it possible to increase acceleration and maintain top speed? I'm 99% sure it's not if you're redline limited and all you change is sprockets. I ask b/c my friend w/ an '05 gixxer 750 just bought some sprocket kit off ebay that includes a front and rear sprocket and it claims no effect on top speed. I asked but he didn't know how many teeth they are. I know going down in front or up in the rear increases accel at the cost of top speed but is this kit just full of crap or what?
Red99TA is offline
post #2 of 11 Old 08-31-2005, 7:35 PM
Re: quick sprocket question
Where are you riding that you'll be able to hit 165 regularly, where a 3 mph loss might be noticed? You can increase accel and maintain (or increase) top speed if you can't pull redline in top gear with the current gearing.
RRWANTR is offline
post #3 of 11 Old 08-31-2005, 8:01 PM Thread Starter
I could give a crap about top speed which is why I went down a tooth up front. I'm asking b/c I'm curious if it's possible or not. I geuss I don't know if his 750 is redline or drag limited at top speed.
Red99TA is offline
post #4 of 11 Old 09-01-2005, 4:44 AM
most bikes dont redline at top speed, therefore if you reduce gearing you might even go faster cos you have a little more power (the power might not be dropping away and thus limiting your top speed)
Bukes are a compromise of useful speed, accel and ridability. My bike is faster top end on a +1 at the rear than as standard as the power curve suits the gearing. However leaving the rear at +1 and making the front -1 causes me to redline (well I would if I had not moved the redline by going the wiring mod to the ECU).
Jon
jonno954 is offline
post #5 of 11 Old 09-01-2005, 7:09 AM Thread Starter
this is off subject but what can I do about my speedo being off since I'm down a tooth up front? Is there a simple solution I can buy for a decent price to make it accurate? I'm getting sick of doing the 10% slower calculation in my head all the time while I'm driving.
Red99TA is offline
post #6 of 11 Old 09-01-2005, 7:14 AM
I don't have a link but do a search on here about the speedohealer...that should help
Northern RR is offline
post #7 of 11 Old 09-01-2005, 7:28 AM Thread Starter
Beat me to it...I just did a search and I actually just ordered the speedohealer. Now I just wish I would've done it a couple thousand miles ago!
Red99TA is offline
post #8 of 11 Old 09-07-2005, 10:21 AM
I added one tooth to the rear and my speedo is still disturbingly accurate according to my gps thingy (and a gearing / engine rev check) its like a couple of percent out....
Weird. Usually I tape over it and dont stop for anything blue and flashy.
jonno954 is offline
post #9 of 11 Old 09-07-2005, 12:06 PM Thread Starter
I went down a tooth up front and I can tell the speedo reads higher than it should. What do our bikes top out at anyways w/ stock gearing? I saw 168 (indicated) at 10,200 rpms on my current gearing which means I was probably only going around 150 - 155.
Red99TA is offline
post #10 of 11 Old 09-07-2005, 12:11 PM
phobiaphobe's Avatar
Reputation Power: 43
My 1000rr will smack the limiter in 6th with one tooth down in the front, whereas it wouldn't quite pull redline in 6th with the stock gearing. I suspect my top speed might be a bit higher.
Here's another wrench in the gears though... I live at about 3000ft above sea level, and I'm convinced that at sea level, with stock gearing, I could pull redline in 6th.
Doesn't matter much to me, just a point of curiosity. Anything over 150MPH is wickedly fast and I'll very rarely have it that high.
edited for typo
phobiaphobe is offline
post #11 of 11 Old 09-07-2005, 9:42 PM
Well my 900rr would hit the redline at 11k in top gear at 185 or so with stock gearing I just went from stock 16t to a 17t and the bike stops pulling at 172 indicated and 10.2k or so. I guess I will dig out the GPS so I can sort some things out. Hey Phobiaphobe I know what you mean 150mph is fast but I work overnight and the freeway is empty when I am heading to work so 150+ is a commom thing for me lol.
Mark 900RR is offline
Sprocket Question bim Honda FireBlade 1 06-25-2005 9:16 AM
Quick Question........ TGZ13 Honda RC51 10 06-03-2005 9:35 PM
Quick question Ice Honda FireBlade 2 11-04-2004 12:23 AM
Under Armor quick question, need an answer quick! deez Riding Gear / Luggage 14 07-15-2004 5:14 PM
A QUICK QUESTION BushrodW Honda FireBlade 6 07-12-2003 2:27 PM
