Raising forks? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 09-01-2005, 9:05 AM Thread Starter
Raising forks?
Hi everyone, I'm trying to raise the forks on my 929 to speed up the steering, I have loosened the bolts on the top and bottum yokes(4 in all) but I cant seem to push the forks up through the headset. I'm I doing something wrong? thanks
CJ550 is offline
post #2 of 6 Old 09-08-2005, 2:17 PM
Re: Raising forks?
you have to spread them a bit with a heavy sccrewdriver...
fst929 is offline
post #3 of 6 Old 09-25-2005, 1:33 PM
Re: Raising forks?
Did you remove the retaining rings on the forks?
K9inAZ is offline
post #4 of 6 Old 09-25-2005, 2:57 PM
HondaGalToo's Avatar
Reputation Power: 31
Re: Raising forks?
From what I understand, it may be better to raise the rear ride height a bit. I think raising the forks may make it twitchier. Just don't raise them a lot. I think some folks here may have done it, a search may yield how many millimeters.
HondaGalToo is offline
post #5 of 6 Old 09-25-2005, 6:35 PM
Re: Raising forks?
Raising the triple clamps 5mm (not dropping them down the fork tubes) made the best compromise between handling and ground clearance along with an additional 1" of ride height in the rear (measured at the tail section above the rear axle, not the shock length).
If your 954/929 is hard to turn in, then you need to eat some Wheaties.
abtech is offline
post #6 of 6 Old 09-25-2005, 6:46 PM
Re: Raising forks?
..and there is the definitive answer!!
Forks done? CBRBob Honda CBR 1100XX 6 08-09-2006 3:18 PM
Raising the Rear wheel without a paddock stand BushrodW Honda FireBlade 8 05-21-2004 8:49 PM
954RR forks Dookie Honda FireBlade 14 04-20-2004 8:38 AM
Raising a lowered Lucky13 Honda FireBlade 2 08-23-2003 9:12 PM
Raising rear height on 929 Ice Honda FireBlade 15 08-01-2003 7:21 AM
