What tools to change tires? - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 09-02-2005, 2:48 PM Thread Starter
What tools do I need to remove and re-install both the front and rear tires off the bike. Not change the rubber, just to take them off. Give them to the tire guy and put them back on? Going to a track day, and the guy will mount the tire, but not take them off the bike.
BTW, I have a 02 954.
1998 CBR900RR - Red - SOLD!!!
2002 CBR954RR - Silver SOLD !!!
2002 CBR954RR - Black SOLD !!!
2005 CR125
2013 BMW HP4 !!! Wow!!!
firebladetoronto is offline
post #2 of 19 Old 09-02-2005, 3:05 PM
NinerPilot's Avatar
Reputation Power: 25
Re: What tools to change tires?
Glad to see you back Deepak! You will need a 32mm socket for the rear axle, a 22mm for the front and a 12mm to take off the front calipers. A screwdriver is handy to help pull the front axel out, as well as a dead-blow hammer or rubber mallet to tap out the rear.
Chris
NinerPilot is offline
post #3 of 19 Old 09-02-2005, 3:12 PM
schnogg's Avatar
Just to remove? I followed someone else's method for that. My tools included a parked car, 2 peices of 2X4's, tire irons or big prybars, and miscelaneous protective rags for those precious brake rotors.
Check this out for background information:
http://www.clarity.net/~adam/tire-changing.html
schnogg is offline
post #4 of 19 Old 09-02-2005, 3:13 PM
schnogg's Avatar
Oops, I read too quickly. I thought when you said tires, you meant tires, not wheels. Well you got a good link anyway.
schnogg is offline
post #5 of 19 Old 09-02-2005, 3:15 PM
sheepofblue's Avatar
Reputation Power: 48
Originally Posted by NinerPilot
Glad to see you back Deepak! You will need a 32mm socket for the rear axle, a 22mm for the front and a 12mm to take off the front rotors. A screwdriver is handy to help pull the front axel out, as well as a dead-blow hammer or rubber mallet to tap out the rear.
Chris
Don't you need to pull the calipers? I assume the 12mm is for the chain tensioners.
Must obey the sheep dog
sheepofblue is offline
post #6 of 19 Old 09-02-2005, 3:16 PM
NinerPilot's Avatar
I fixed it. The 12 is for the calipers not the rotors. I wasnt thinking of adjusting the chain as that is another project anyhow.
Chris
post #7 of 19 Old 09-02-2005, 3:19 PM
dB
Chris
12mm is also used for the front axle pinch bolts.
dB is offline
post #8 of 19 Old 09-02-2005, 3:43 PM Thread Starter
Chris
Cool, deep sockets or reg?
And don't worry, I won't be attempting this without proper supervision. Just want to make sure there is nothing Honda specific that might not be at the track.
And yes, my error, I want to remove the wheels from the bike, not the tires from the wheel.
Good to be back...busy with making babies. My second kid (boy) was born 5 weeks ago...this will be my first track day of the year!!
Going to try and make it to the gap in Oct...you coming?
2005 CR125
post #9 of 19 Old 09-02-2005, 4:43 PM
NinerPilot's Avatar
Gimme some heads up and Ill try to make it out there. I am usually found in that part of the state every weekend in Oct. Camping. Normal sockets are fine.
Congrats on the new addition!
Chris
post #10 of 19 Old 09-02-2005, 10:30 PM
Reputation Power: 19
Chris
saf has a video how to do this bottom of this page
matt232 is offline
post #11 of 19 Old 09-02-2005, 10:31 PM
phobiaphobe's Avatar
Reputation Power: 43
Visa Gold.
phobiaphobe is offline
post #12 of 19 Old 09-02-2005, 10:40 PM
jetbdude's Avatar
Reputation Power: 28
Send a message via AIM to jetbdude
Are you going to the Shanonville track day on September 9?
jetbdude is offline
post #13 of 19 Old 09-03-2005, 1:37 AM
Send a message via AIM to Aychdot Send a message via Yahoo to Aychdot
Removal is the easy part. Getting the back caliper to stay in place on re-installation is the hard part. After you do that a couple of times it's not so bad though (if using stands, a 2x4 under the tire and or a freind will be a great help).
Aychdot is offline
post #14 of 19 Old 09-03-2005, 7:56 AM Thread Starter
right track, wrong date. It will be the Pro6 track day on Sept 19th.
coming?
2005 CR125
post #15 of 19 Old 09-03-2005, 10:27 AM
jetbdude's Avatar
coming?
I might go to the Sept 9 one.... was not aware of the one on the 19 though.... Would be nice
jetbdude is offline
What tires to get? Turboedsupe Honda CBR 600 11 08-25-2005 10:12 AM
Do I need to change tires? ** Pics Added ** mr_rua General Discussion 15 09-01-2004 10:17 AM
Who changes their own tires? which tools to get Rios929 General Discussion 33 08-27-2004 12:36 PM
Inherited some tools, what should I make? NinerPilot Off-Topic 10 01-25-2004 8:40 AM
Those of who change own tires..... jdev Honda FireBlade 18 11-27-2003 9:48 AM
