954 front master cylinder - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 09-09-2005, 1:56 PM Thread Starter
I bought a 954 back in May. After my 600 Hornet, the power, handling, and braking of the blade is just amazing.
Question:
The front brake master cylinder is kind of leaning over at around 45 degrees from the horizontal, i.e. if I were to just remove the filler cap, the brake fluid would just pour out - to top up the level, I would have to first disconnect the resevoir from the brake lever assembly and get somebody to hold it upright.
I hope this is clear without any pics.
I had just assumed that this was some poor design. But looking a few picks, I'm now not so sure. Can anybody advise?
chetty
chetty is offline
post #2 of 3 Old 09-09-2005, 2:03 PM
Re: 954 front master cylinder
With the bike leaning on the sidestand and the bars turned fully to one side ( I forget whether it is left or right, but you'd find out quick enough) the fluid levels out, and you can add as needed.
BDA116 is offline
post #3 of 3 Old 09-11-2005, 5:29 AM
Just in addition. If your front brake reservour needs more break fluid I would recommend bleeding the system and fill with new fluid. It is not a good idea to add fluid if you are not sure what fluid is already in the system.
jaim is offline
929, 954 front brake master cylinder piston size. CraigB Honda FireBlade 9 11-28-2006 7:22 PM
Front brake master tech cylinder question G-Force Junkie General Discussion 13 11-24-2004 1:59 AM
Brembo front master cylinder 425954guy Honda FireBlade 9 11-04-2004 12:01 PM
Question: 954 vs. 929 Front Master Cylinder Chrome Dome Honda FireBlade 5 08-29-2004 2:14 PM
929 front brake master cylinder, 954 same??? bligz Honda FireBlade 9 12-17-2003 3:38 PM
