Droppin a 954 Motor into a 929... - Honda Motorcycles - FireBlades.org
post #1 of 31 Old 05-15-2003, 1:39 PM Thread Starter
Re: Droppin a 954 Motor into a 929...
On Sunday my buddies 929 engine seized...it's a pile of scrap now. He was just riding in a straight line...hmmm weird.
He's set on purchasing a complete 954 motor with the computer and everything.
He called Dan Kyle and Dan said it wouldn't be a problem...I thought it was harder then that.
How hard is this going to be to install? We plan to drop the old 929 engine tonight and get it prepped for the new engine.
Any input? Advice?
Will we need a 954 swingarm also (because of where the swingarm mounts) or will the 929 swingarm work fine? Thanks in advance.
2001 CBR929
1996 ZX6R Race
2000 XR50
WOTBlake is offline
post #2 of 31 Old 05-15-2003, 1:47 PM
ND4SPD's Avatar
Reputation Power: 50
How did it seize up just out of the blue??
Maybe he should learn to check the oil before riding
ND4SPD is offline
post #3 of 31 Old 05-15-2003, 2:25 PM
Yeah, that's kind of freaky. Unless he was riding in a straight line at an 11 o'clock posistion on one wheel for a while.
rockets25 is offline
post #4 of 31 Old 05-15-2003, 2:32 PM Thread Starter
Well he was riding along, it lost power. He pulled over...tried to push start it...the rear tire just skidded. Drained the oil...pieces of metal.
The local tuner/mechanic said it as toast.
2001 CBR929
1996 ZX6R Race
2000 XR50
WOTBlake is offline
post #5 of 31 Old 05-15-2003, 2:33 PM
If Dan said it was just a drop in, then it probably is...
ConqSoft is offline
post #6 of 31 Old 05-15-2003, 2:50 PM
ND4SPD's Avatar
I'd check to make sure it's not the clutchbasket or something. Wasn't there a recall on that??
ND4SPD is offline
post #7 of 31 Old 05-15-2003, 2:53 PM
nomad's Avatar
I'd check for a second opinion.
I had a seized engine while riding... it's not just something that lets you pull over.
I thought the 929 had an engine mounted swing arm where the 954 did not? How does that work when switching engines?
Jordan H.
The three most feared words in racing, "Powered by Honda".
nomad is offline
post #8 of 31 Old 05-15-2003, 3:00 PM
ND4SPD's Avatar
They both have engine mounted swingarms, just different dogbone I think
ND4SPD is offline
post #9 of 31 Old 05-15-2003, 3:17 PM Thread Starter
ND4SPDSHO : They both have engine mounted swingarms, just different dogbone I think
Thats what I thought.
Well, my buddy said the engine starting making a 'hissing sound' and he pulled in the clutch...after a few seconds the engine shut off. When he got it stopped and tried to push start it the rear tire would just skid.
The guy who looked at the engine has been a bike mechanic for 20 years. He's the service manager for the local bike shop. If you want your gsxr1000 to make 175hp at the wheel...he's the guy to see. He has a dyno, does custom maps, rebuilds engines, etc, etc Damn good mechanic...
2001 CBR929
1996 ZX6R Race
2000 XR50
WOTBlake is offline
post #10 of 31 Old 05-15-2003, 3:42 PM
Bolt in deal. *Make sure to use the computer and whole FI set-up as it is different than the 929's. *If he's not changing the wiring harness to the 954's, make damn sure it is EXACTLY the same before you try using it. *Wires could be different even if the plugs are the same.
As long as you bolt up the engine bracket from the 929, no problem.
luvtolean is offline
post #11 of 31 Old 05-15-2003, 4:29 PM
I think this is way too much hassel for what it's worth.
Check ebay, I see 929 complete motors quite often.
Tank69 is offline
post #12 of 31 Old 05-15-2003, 4:49 PM
I just thought of something else, the intake snorkels are probably different as the diameter of the throttle bodies, and the airbox is different on the 954.
post #13 of 31 Old 05-15-2003, 5:53 PM
Probably an oil pump failure?
Denny is offline
post #14 of 31 Old 05-15-2003, 10:59 PM
Or lost coolent, and fried the motor.
G-Force Junkie is offline
post #15 of 31 Old 05-15-2003, 11:26 PM
ND4SPD's Avatar
If he heard hissing, he probably lost coolant and overheated the thing
ND4SPD is offline
954 shock for 929?, other "better" OEM? 2bitsamile Honda FireBlade 2 12-01-2003 8:36 PM
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 8:27 PM
929 vs 954 wheels shogan Honda FireBlade 6 09-08-2003 7:08 PM
954 headlight fit the 929? AfterShock Honda FireBlade 6 07-17-2003 1:20 PM
