HINDLE BOLT-ON - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 05-17-2003, 4:35 AM Thread Starter
BushrodW's Avatar
Send a message via Yahoo to BushrodW
Re: HINDLE BOLT-ON
Hey there all y'all. Well... She Who Must Be Obeyed (SWMBO) and I recently returned from 3 weeks in Paris. My...what a great city that is. And THE BIKES!!!!!!
Anyway....it's good to be back.
I put a Hindle bolt-on on the 929 a while back. I've run two maps so far: The 49 State Erion b/o map and the 49 State Jardine b/o map. The Jardine map is the better of the two..there's less 'flutter' in the exhaust note as the HTEV transitions to the open from closed position (around 6500 to 7000 rpm, as you all know). The fuel mileage is a bit better on the Jardine. The bike also seems to pull a bit better w/the Jardine map.
Does anyone with a 49 State 2001 929'er have any input on other Power Commander canned maps for other manufacturer's bolt-on's they've used with their Hindle bolt-ons?
Does anyone have any words of wisdom regarding using, say, a Mori half-system map with a Hindle bolt-on can?
I am also in the end stages of experimenting with .07 mm electrode NGK Iridium plugs. I'll replace them with .04 mm electrode NGK 'Laser Iridium' IMR9A-9H (6966) plugs that I got from Ron Ayres motorsports. These are supposedly the same as the relatively new NKG .04 mm iridiums with a Honda part number, in a red and white box. $10 or $12 each or so verses approx. $17 each for the Honda p/n item. At any rate, we'll see how they work. Can't be any worse than the .07's. I don't care for the way the bike starts cold with those. More current to a bigger electrode, I suppose, maybe makes for less crisp starts.
Well. as usual, TIA for any replies. I appreciate'cha.
Bushrod W.
www.AirAmericaRadio.com
BushrodW is offline
hindle sounds superRR Honda FireBlade 2 12-01-2003 8:38 PM
Oil on the frame slider bolt. CBRjack Honda FireBlade 5 08-24-2003 6:15 PM
Hindle High-mount for 954 PATBAROK Honda FireBlade 1 08-18-2003 6:00 PM
Hindle bolt on Gadget369 Honda FireBlade 11 08-18-2003 12:10 AM
