coolant leak on my 929 - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 08-18-2003, 1:34 AM Thread Starter
Re: coolant leak on my 929
First time dealing with a coolant leak of any sort. Haven't had the time to pull anything apart to look at a possible source of the problem.
Noticed during a stop at the mall that there was green fluid dripping out of my fairings. Left a pretty good mess too. Air-cooled it home.
Anyway, don't know if I have time to play with it during weekdays, wish me luck.
I hope it isn't too hard to diagnose the problem. But what it only occurs during high pressure and heat. Would I need to get those coolant system pressurizer thingys (sorry, I know what it does, but don't know the proper term) to simulate the load to discover where the leak is?
Is changing the water pump hard?
Be fast or be last.
asiliat is offline
post #2 of 15 Old 08-18-2003, 1:45 AM
Changing the water pump is a piece of cake. Sounds like you might be facing the possibility of a small crack around either the inlet or outlet pipes on the radiator. A pressure test of the radiator will determine that. Good luck, hope it's something easy and cheap to fix.
Latebraking is offline
post #3 of 15 Old 08-18-2003, 8:26 AM
This could be caused by using improper radiator fluid. If you use stand anti-freeze that is not silicate free it will cause your water pump seals to leak. Do you know if the bike has run with anything other than motorcycle radiator fluid?
ibAdam is offline
post #4 of 15 Old 08-19-2003, 3:32 PM Thread Starter
AFAIK, it's motorcycle rad fluid. Last time it was changed, it was done at the shop (I'd do it myself, but didn't have time, and was on a trackday the next morning).
Maybe they fudged it up?
Be fast or be last.
asiliat is offline
post #5 of 15 Old 08-19-2003, 6:35 PM
Latebraking, you must be a hell of a mechanic to be able to diagnose a coolant leak with out seeing the bike. Don't shoot from the hip and give this man shoddy advice. The only way to find the leak is to remove fairings and pressurize the cooling system.
fusion929rr is offline
post #6 of 15 Old 08-19-2003, 6:50 PM
You gotta take the fairings off. Take them off and go ride it until it gets hot enough to leak. Then spend some time just looking at everything, you should be able to find the location of the leak pretty easily.
If the pump seals are bad, you'll see coolant coming out of a little hole on the bottom of it, made just for this, to tell you it's bad.
luvtolean is offline
post #7 of 15 Old 01-23-2011, 9:43 PM
Did you get this figured out? What did you determine? I think I am facing the same exact issue on my 929. Thanks
bhanleyjr is offline
post #8 of 15 Old 01-23-2011, 11:03 PM
Reputation Power: 11
Hopefully I'll be able to work on mine this week. I'm having the same problem. I noticed it dripping when I was running the bike while checking it out. I just bought the bike a week ago and I'm storing it at my buddies house.
I'll be ripping into it as soon as I can because I want to change the oil, filter, spark plugs and coolant anyways.
I'll post what I find out.
Punk is offline
post #9 of 15 Old 01-23-2011, 11:16 PM
I am going to pressure test as a first step myself, should be getting around to it next weekend. I will be very interested to know what you find if you get around to your bike before I do mine.
Thanks
post #10 of 15 Old 01-24-2011, 3:00 AM
Reputation Power: 12
It could be something as simple as the hose clamps biteing into the coolant hoses, this happened to my RC51.As posted, take the fairings off to see where it is leaking.
mondo is offline
post #11 of 15 Old 01-24-2011, 8:31 PM
I hope to check mine out tomorrow night if things work out.
I'll let you know.
Punk is offline
post #12 of 15 Old 01-26-2011, 10:44 PM
Ok, I pulled the lower fairing off and everything is dry. I started it up and still dry. I let it get up to temp.......still dry. 10 minutes of running, and not even a drop.
The over flow tank is in the upper level and the bike didn't over heat so I'm assuming everything is topped off. I wasn't able to check before going home since it was still hot. I'll get to it this weekend when I change the oil.
Sorry, nothing to report today.
Punk is offline
post #13 of 15 Old 03-05-2011, 10:09 AM
Update;
The upper hose is leaking at the top. Seems the clamp may be loose. Didn't get a chance to pull the fairing last weekend. Going to fix it this weekend.
Punk is offline
post #14 of 15 Old 03-05-2011, 10:16 AM
Originally Posted by Punk View Post
Update;
I got a hole in my radiator last week probably from a stone. I have to fill it before every ride. As the pressure builds it squirts water directly onto the front tyre which has caused some very interesting corner entries during the week :-)
Need to find time to pull it off and solder it up.
post #15 of 15 Old 03-06-2011, 4:10 PM
Dude, that's some scary stuff!
Tightened the hose today. Now I just need a nice day to take a ride to see if it's fixed. Damn I can't wait til this friggin snow is gone.
Punk is offline
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 8:27 PM
coolant change bladeleeder Honda FireBlade 9 08-16-2003 11:28 PM
