WASHED MY BLADE and now it wont start - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 01-07-2006, 12:00 PM Thread Starter
Hi all, I am a new member.
I own a cbr 900 rrr, and have not had any problems with it ever. Ok so I washed it about 3 weeks back, and tried starting it and nothing. Everything is working, fuel pump, starter, lights, indicators, and even sparking, but nothing. I checked everything with a multi-meter and all looks good. The engine turns over as long as I keep cranking it. But as soon as I let the starter switch go, the engine stops too. (only turns when pressing the switch). I am pulling my hair out. The only thing which is not powering is the rectifier. Could this stop the bike from starting ?? everything was fine until I washed it(what an idiot I am), no problems ever. But now the engine will not fire up. Please any help would be great !! many thanks.
brokenfireblade is offline
post #2 of 14 Old 01-07-2006, 12:02 PM
phobiaphobe's Avatar
Reputation Power: 43
Re: WASHED MY BLADE and now it wont start
I hate to be the guy that says kill switch...
I got caught with that last night. Went to start my blade up to blow the carbon out and it would just crank and crank and crank but no fire. Didn't take me too long to figure out what it was but I still felt like a tit.
phobiaphobe is offline
post #3 of 14 Old 01-07-2006, 12:08 PM
Just to cover all bases I'd say get it dirty again and then see if it starts. If it does, the problem is obvious
esoteric is offline
post #4 of 14 Old 01-07-2006, 2:59 PM
Thats why I never wash mine
1998 CBR900RR - Red - SOLD!!!
2002 CBR954RR - Silver SOLD !!!
2002 CBR954RR - Black SOLD !!!
2005 CR125
2013 BMW HP4 !!! Wow!!!
firebladetoronto is offline
post #5 of 14 Old 01-09-2006, 10:52 AM Thread Starter
Ok heres the update. I have checked all points on the bike.
Its NOT the KILL switch,
Fuel pump is working,
Ignition pulse generator is working,
Starter motor is working,
God-damn everything is working that should be.
Ignition spark coils are working fine too.
Anyone have any ideas ?? I am pulling my hair out. Please help. The only thing that I do not know how to check properly is the Ignition control module. Does anyone know how to test it ?? Many thanks. P.S. If this fails I better get ready to dig deep into my pockets. The bike is getting fuel, spark, and air. Whats wrong ???
post #6 of 14 Old 01-10-2006, 7:50 PM
did u try push startin ur bike?? It mights work and from there, u can check ur voltage to ur battery...
Murphy is offline
post #7 of 14 Old 01-10-2006, 8:50 PM
Ok, lets go back a bit. Just how did you wash the bike? (i.e. pressure washer, etc)
Could it be you got water in the fuel tank? Or in any other place where it would cause this problem. Just a guess.
Bikes and women - both have nice curves.
GhostRider is offline
post #8 of 14 Old 02-12-2006, 10:03 PM
how long has the bike been drying? maybe something just got wet and when it drys out it will fire up just like old times.
Diceman is offline
post #9 of 14 Old 02-12-2006, 10:19 PM
Well, let's see. The first post was made over a month ago and it says he washed it 3 weeks before that. So I would guess it's had about 2 months to dry out.... Is it me or do people quite often not read the fukken posts before they start asking questions to which the answers are in the post they just supposedly read?
I think I worded that correctly...
Getsome is offline
post #10 of 14 Old 02-13-2006, 12:37 AM
stegen's Avatar
Reputation Power: 22
check the fuses
Life is Good, Life is Great
stegen is offline
post #11 of 14 Old 02-13-2006, 12:42 AM
next time you wash it get a spray bottle of spray on wax and windex forget the damn pressure washer and all the other stuff that just makes everything wet..... all by hand takes more time but the results are much better~
anabatic is offline
post #12 of 14 Old 02-13-2006, 6:36 AM
remove sand from vagina.
Diceman is offline
post #13 of 14 Old 02-20-2006, 2:51 AM
Well you need two things for your engine to work, a spark and fuel. make sure your getting both of those and you should be good. If that still doesn't work then i would try and find someone with a manul for your bike and see what it has in the troubleshooting section for bike not starting.
also try jump starting it. if that works then its most likely your battery, stator, or rectifier. Let us know if you get it working.
-Quinc
Quinc is offline
post #14 of 14 Old 02-20-2006, 2:56 AM
This is what it says in my 929 manual..
ENGINE DOES NOT START OR IS HARD TO START
Possible cause
Faulty fuel pump (Section 5) 1 . Check for operation of the fuel pump
Normal
2 . Inspect the fuel flow
I
Normal
3 . Inspect the fuel injector
I
Normal
4 .1
erform a spark test
Good spark
1
5 . Test cylinder compression
Compression normal
6. Starting following normal procedure
Engine does not start
7 . Remove and inspect spark plug
22. TROUBLESHOOTING
Abnormal
Abnormal
Abnormal
Low compression
Engine starts but stops
Wet plug
Faulty pressure regulator (~ection 5)
See section 5
Weak or no spark
• Faulty spark plug
Fouled spark plug
Faulty ECM
Broken or shorted spark plug wire
Faulty ignition switch
Faulty ignition pulse generator
Faulty engine stop switch
Loose or disconnected ignition
system wires
Valve stuck open
Worn cylinder and piston ring
Damaged cylinder head gasket
Seized valve
Improper valve timing
Improper starter valve operation
Intake pipe leaking
*Improper ignition timing (Faulty
ignition coil or ignition pulse generator)
Fuel contaminated
• Starter valve closed
*Throttle valve open
Clogged air cleaner
Quinc is offline
CBR 929 wont start now... help? Tempest929 Honda FireBlade 6 10-22-2005 10:14 PM
Bike wont start GonZilla Honda FireBlade 30 11-09-2004 5:52 AM
help 1000rr wont start kc1717 Honda FireBlade 5 07-11-2004 6:12 PM
Bike Wont Start djice929 Honda FireBlade 12 11-18-2003 5:15 PM
929 wont start 929rrrider Honda FireBlade 8 10-24-2003 11:34 AM
