LSL Steering Damper - HELP - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 01-09-2006, 7:07 PM Thread Starter
I've got the chance to pick up an LSL steering damper for my 929 cheap, but can't work out how it fits to the bike from the supplied pictures...I suspect it sits somewhere off to the left-hand side (clutch side) rather than across the tank like an Ohlins.
Has anyone used one of these dampers ?, or seen one on a 929 to be able to tell me how it mounts ?
...And of course the big question - are they any good ??
- Cheers, Spanky.
Spanky is offline
post #2 of 4 Old 02-02-2006, 5:28 PM Thread Starter
Re: LSL Steering Damper - HELP
OK, so here's an update just for the record in case someone else comes up with the same question.
I bought the LSL damper that was on offer through eBay.
Its German made, and has 7 available damping positions - from nearly nothing to quite stiff.
The damper fits on the top triple clamp under the steering stem nut (the kit comes with a slightly thinner nut to keep everything tidy) with a cast finger that fits down into the front left hand side to keep every safe and prevent any movement.
One end of the damper rod is attached to the fitting that mounts on the top triple clamp, and the other to the mounting bracket that fits on the frame at the front tank mount.
...Which means when its fitted it doesn't sit straight across the frame a la Ohilns, but at an angle (roughly parallel to the left clip-on) across the front left of the tank - looks pretty good actually.
You'd think it'd get in the way all the time, but the only time I've noticed it was at hard left lock turning out of a gas station.
As for riding stability - I've never gone so hard over the rough, bumpy road I use for my Saturday morning blast with such confidence - the bike is SO stable now its amazing !. (I'm running on the 5th out of 7 clicks adjustment).
The only thing I've noticed (and I'm sure its pretty true for most dampers) is that in cornering I need to apply a little more pressure to the bars than I used to. In the past I'd really only need to 'think' about tightening my line and it'd happen, now I need to make a conscious effort to push the inside bar.
Otherwise, it's the best money I've spent on the bike in a long time !.
Cheers, Spanky.
Spanky is offline
post #3 of 4 Old 02-02-2006, 6:03 PM
Tornado bait's Avatar
Reputation Power: 27
I wouldn't mind seeing a pic of the install.
I do all my own stunts.
Tornado bait is offline
post #4 of 4 Old 02-03-2006, 7:21 AM Thread Starter
Hi TB,
here take a look at these...
Cheers, Spanky
ID:	16924 Click image for larger version
ID:	16925 Click image for larger version
ID:	16926 Click image for larger version
ID:	16927 Click image for larger version
Spanky is offline
steering damper f/s jayd929rr For Sale 0 10-30-2005 9:55 AM
Steering Damper kerrycorcoran Honda FireBlade 2 03-30-2005 11:26 AM
arrow steering damper fitting help! mikeyhblade Honda FireBlade 2 02-11-2005 3:22 PM
Steering Damper saf Honda RC51 15 01-04-2005 11:56 PM
steering damper rogerjt General Discussion 5 12-27-2004 12:46 PM
