929 throttle questions - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 01-24-2006, 12:31 PM Thread Starter
dmz
Hi everyone,
I have a '01 929 with PC3 and slip-on exhaust. I noticed that the throttle on my bike is very abrupt at lower RPM. For example when I take on a tight corner and I am around 3-4k RPM and roll off the throttle entering the corner, half way thru the corner I want to give some gas to accelerate out of the turn smoothly. Well, most of the time when I try to get on the gas slowly, I usually get nothing and all the sudden I get too much and the bike almost lunch forward. Is this normal for all the 929 or my PC3 is not tuned properly? Doe this happen to people with stock bike? How about modded? My previous bike was a stock R6 and it was a hell lot smother on these situations.
Thanks,
dmz
dmz is offline
post #2 of 15 Old 01-24-2006, 12:35 PM
Re: 929 throttle questions
Yeah, the 929 had a rough transition down low.
Do you have a custom map for your PCIII? That should really help.
luvtolean is offline
post #3 of 15 Old 01-24-2006, 12:41 PM
southpark460's Avatar
Reputation Power: 17
Send a message via AIM to southpark460 Send a message via Yahoo to southpark460
Mine's twitchy too. Custom map is on the list for this winter. Also, it seems if your suspension is too stiff, it makes the throttle very twitchy. Still working on suspension tuning too...
southpark460 is offline
post #4 of 15 Old 01-24-2006, 1:55 PM Thread Starter
dmz
I bought my bike with the PCIII already installed. So, I don't know if I have a custom mapping. Most likely not. Anyone had the throttle smoothed out with a custom map?
dmz is offline
post #5 of 15 Old 01-24-2006, 2:24 PM
HondaGalToo's Avatar
Reputation Power: 32
Yup, the custom map helped with my full exhaust. Gearing changes helped, too, on the track, because slow turns I had to take in first gear with the stock gearing I can now do in second with the changed gearing (-1 front, +1 rear). The throttle was particularly touchy in first.
HondaGalToo is offline
post #6 of 15 Old 01-24-2006, 5:00 PM
Hi dmz,
I just installed a PC3USB I bought second hand from a guy who had exactly the same mods as me. He had spent $300 on a custom map and from the difference I've noticed with my bike I'd say it was money VERY well spent. It no longer has the 'light-switch' on/off throttle, its crisp, and pulls hard when whacked open - just a whole new bike !
The PC3 comes standard with a generic map for the 929 as stock - no mods. It should smooth things out a little, but if you're still finding things are very abrupt I'd have the thing checked out on a dyno - who knows what the guy who had the bike before you has done to it ? (you can alter settings etc manually by using the buttons on the front of the unit rather than using a laptop - maybe he had a play with these ?).
You could always jump onto the Dynojet website and check out the list of maps they have there for downloading to see if you can find something that suits your bike - at least then you'd know where you were at with it...
The PC3 gives you the ability to tune out the symptoms you're describing provided fuel quality, air filters, and engine tune are all OK - I have assumed in writing this that you don't have any of these issues with the bike ?
Good Luck !
Spanky is offline
post #7 of 15 Old 01-24-2006, 5:04 PM
Originally Posted by dmz
Hi everyone,
Thanks,
dmz
Hey, just a quick thought, it's a bit of a long shot but 3,000rpm is where the HTEV is opening - you don't have a problem with that do you ?
Cheers, Spanky
Spanky is offline
post #8 of 15 Old 01-24-2006, 8:03 PM
EatnAsphalt's Avatar
Reputation Power: 19
My 929's throttle was considerably smoother after I sync'd the throttle bodies. Still has some lurching coming off of closed position but not nearly as much. I have a Micron slipon and a PC3, but no custom map.
Andy
EatnAsphalt is offline
post #9 of 15 Old 01-24-2006, 11:56 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Check the slack in your throttle cable(s) too.
Red Rider is offline
post #10 of 15 Old 01-28-2006, 6:11 PM
Reputation Power: 15
what pipe are you using?
Maser is offline
post #11 of 15 Old 01-30-2006, 12:41 PM
I had some slight lag before changing my oil. I had the impression that the bike came with normal automotive Mobil 1 Synthetic in it. Switched to a real motorcycle oil and the lag seemed to go away.
That could be somewhat placebo, but it seemed to make the difference.
Pulski is offline
post #12 of 15 Old 01-30-2006, 3:30 PM
CBR929RE's Avatar
Reputation Power: 39
damn I wish I still had my bike. it never had this issue. and I kinda worry that if I get another one its gonna be like that.
CBR929RE is offline
post #13 of 15 Old 01-30-2006, 11:58 PM
I simply learned to ride with it 100% stock. No feel that I need something different & yes I can notice the better 954 set-up, but at home on both of them. Could be that in a month I should be into my 60 continual year of riding & then close to 76 yrs of age-----well mid July anyway.Guess I have ridden with some of the strangest things yes to even left hand throttles & hand gear changes with foot clutches to you name it for I was part owner of several m/c shops from '48 till '53.
Smitty is offline
post #14 of 15 Old 01-31-2006, 12:30 PM
CBR929RE's Avatar
Smitty, you rule. You're my hero.
CBR929RE is offline
post #15 of 15 Old 01-31-2006, 5:15 PM
75 and on two blades... I salute you sir.
Pulski is offline
929 throttle bodies on a 954 oneoblivion Honda FireBlade 4 08-10-2005 4:21 PM
new 929 onwer has questions jumpy Introductions 16 07-13-2005 10:55 AM
929 "hesitating" at full throttle? oshkarmeyer Honda FireBlade 3 06-07-2005 11:26 AM
A few Clutch Questions 929 c_reber Honda FireBlade 6 05-25-2005 4:08 PM
929 mapping questions/need'd benisgod Honda FireBlade 7 09-15-2004 4:43 AM
