sss conversion - Honda Motorcycles - FireBlades.org
post #1 of 28 Old 02-28-2006, 11:48 PM Thread Starter
sss conversion
i have a 750 sss that im told will drop right in but the stock 900 rim/tyre does not clear the swingarm and the sss requires some clearencing to work ,i hope someone can help with a bit of info or advice on this matter thanks
sidfishes900 is offline
post #2 of 28 Old 02-28-2006, 11:52 PM
Re: sss conversion
If you are talking about a VFR single sided swingarm conversion, you're gonna have more problems trying to fit a stock 900 rear rim to it than it just clearing the arm.
I know there is a website documenting someone doing this, but I don't remember it off the top of my head. If I find it I'll post it.
BDA116 is offline
post #3 of 28 Old 02-28-2006, 11:59 PM Thread Starter
Re: sss conversion
Ok i had a feeling this may be the case, whats your thoughts on my options as far as wheels go? thanks
post #4 of 28 Old 03-01-2006, 12:08 AM
Re: sss conversion
You could do the easy way, and fit a VFR wheel, or do it differently, and fit a Ducati wheel or one from any number of aftermarket manufacturers. Or Get a SSS kit from RAAM and do it the $$$$ way.
Latebraking is offline
post #5 of 28 Old 03-01-2006, 12:08 AM
phobiaphobe's Avatar
Reputation Power: 43
Re: sss conversion
You need to use the VFR rim too. It's like a car rim.
phobiaphobe is offline
post #6 of 28 Old 03-01-2006, 12:23 AM Thread Starter
Re: sss conversion
Ok I'll check the options out , i'm just getting started on this and have lots to learn about this project , thanks a lot guys, this is a good site i will be using it/ you to rehab my wadded up rr and make it live again.. thanks again and sorry about chuck norris
post #7 of 28 Old 03-01-2006, 2:38 AM
Re: sss conversion
Don't ever take the Chuck's name in vain.
post #8 of 28 Old 03-01-2006, 2:49 AM
NinerPilot's Avatar
Reputation Power: 25
NinerPilot is offline
post #9 of 28 Old 03-01-2006, 2:59 AM
Repeater's Avatar
Re: sss conversion
I don't get it why change to a single sided. is it for bling factor alone?
Repeater is offline
post #10 of 28 Old 03-01-2006, 12:44 PM
Re: sss conversion
It must be. I think it's too much money + work to replace something that already works great. That is - unless a crash was involved and parts need to be replaced anyway.
I can't say anything. There's not much on my bike that hasn't been altered.
Custom900 is offline
post #11 of 28 Old 03-01-2006, 12:46 PM
Re: sss conversion
How about ease of maintenance?
post #12 of 28 Old 03-01-2006, 12:49 PM
Re: sss conversion
Originally Posted by NinerPilot
That is the one I was thinking of.
BDA116 is offline
post #13 of 28 Old 03-01-2006, 1:38 PM
Reputation Power: 19
Re: sss conversion
From what I've heard you gain about 20 lbs and lose some rigidity with the single sided swingarm. Strictly bling factor, although I do like the look. As far as maintance, maybe, but instead of buying a regular rear stand, you have to buy one for a single sided swingarm, which I think are more costly? I think the process of making chain adjustments get a little messy too?
Jake is offline
post #14 of 28 Old 03-01-2006, 1:39 PM
Re: sss conversion
Originally Posted by Jake
...I think the process of making chain adjustments get a little messy too?
Chain adjustments are a piece of cake.
post #15 of 28 Old 03-01-2006, 1:41 PM
Re: sss conversion
How about changing out the rear tire with the exhaust can there?
Jake is offline
VFR swingarm conversion? EXOTIC900RR Honda FireBlade 85 11-19-2019 4:28 AM
Swingarm conversion advice CRU Honda FireBlade 15 09-10-2008 11:10 PM
Cable clutch conversion Pete Honda RC51 30 08-13-2008 8:37 AM
file conversion???????? xraycatj Off-Topic 3 06-25-2005 12:13 PM
Fireblade Conversion Help Baba san Erion Europe 1 07-30-2004 6:13 PM
