necessary to refresh coolant 929RR? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 03-24-2006, 3:45 AM Thread Starter
Hello guys, i have a question. my bike is a 6/2001 929RR the coolant is till now never been refreshed is this really necessary. Is this a technical diffucalt
job and how does it works, are the tricks?
timace is offline
post #2 of 8 Old 03-24-2006, 8:49 AM
HondaGalToo's Avatar
Reputation Power: 32
Re: necessary to refresh coolant 929RR?
Coolant should be changed every 2 years. It's not hard. On my 929 I pull off the one lower hose and let it drain into a big aluminum roasting pan. Then I pull off the small hose that goes to the overflow and drain that, too. My changes are due to switching to distilled water for track season, so I refill, run to above 180, drain, and repeat a few times until it's running clear. You probably don't need to flush it as much, I'm not sure what the recommended procedure is for that.
HondaGalToo is offline
post #3 of 8 Old 03-24-2006, 9:24 AM Thread Starter
so i must onley unlock te hose of the reserve tank and from the radiator? nothing at the pump? After refill start the engine with the fill dops of the thank to get the air out?
timace is offline
post #4 of 8 Old 03-24-2006, 9:30 AM
CBRBob's Avatar
You dont really need to run it to 180deg every time. The coolant will flow enough to flush out the old stuff, there is a bleed hole in the thermostat. Be careful of the hot water and pouring room-temp water into a hot engine block can cause cracks
Make sure you get a silicate-free coolant. Make sure it actually says that on the label. The silicates(ultra-fine sand) will destroy your water pump seal and you will be changing the coolant again very soon, though not by choice that time.
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #5 of 8 Old 03-24-2006, 9:31 AM
There is a screw on the water pump that you can unbolt and drain the coolant from there. Much easier then removing the hoses IMO. When you're refilling it (flush it w/ distilled water only) leave the rad cap off, turn the bike on, blip the throttle a few times then fill as needed.
Nickelii is offline
post #6 of 8 Old 03-24-2006, 9:37 AM
Kuss929's Avatar
There are 2 drain screws one on the pump and one on the front of the engine left side just under the header. Mine has a "C" stamped on it for coolant.
There are some who call me ............................Tim
Kuss929 is offline
post #7 of 8 Old 03-24-2006, 9:37 AM Thread Starter
thank you for the good info
timace is offline
post #8 of 8 Old 03-24-2006, 9:58 AM
Thanks for that tip. I hadn't thought about that. I thought I had to run it up that high to get the thermostat to open. So, I should just run it a bit, not up to 180? I'll try that this year. So far, so good, but I won't take that chance again...
Although, I think I let it cool down for at least 15 mins before emptying and refilling, so I didn't burn myself draining the hot coolant.
Hindle Link Pipe Necessary??? gthotchkiss Honda FireBlade 1 12-09-2005 4:31 PM
Changing Coolant / Flushing Coolant? cbr9two9guy Honda FireBlade 3 07-10-2005 10:13 AM
Where to hook helmet up to on rear seat of 929RR JWHT Honda FireBlade 12 09-30-2004 4:25 PM
How To coolant drain/flush trey Honda FireBlade 1 08-20-2003 11:17 PM
Necessary to replace exhaust gaskets Oz Honda FireBlade 7 06-26-2003 5:14 PM
