929 Valve cover removal - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-29-2006, 6:10 PM Thread Starter
Can anybody tell me if it is possible to remove the valve cover without dropping the motor? I just got my bike back together and it doesnt run worth a damn, I think my timing may be off.
Blur929RR is offline
post #2 of 7 Old 03-29-2006, 8:34 PM
CBRBob's Avatar
Re: 929 Valve cover removal
Yep, loosen the radiator and sneak it out the front.
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #3 of 7 Old 03-29-2006, 8:39 PM
EatnAsphalt's Avatar
Reputation Power: 19
Yes, the cover comes out without removing the motor. You won't think it will, but it slides out towards the rear of the bike. You'll either need to remove the throttle cables from the throttle body or pull them at the bar and pull them out of the way.
Edit: Hmm, never tried dropping the rad and going forward with it.
Andy
EatnAsphalt is offline
post #4 of 7 Old 03-29-2006, 11:19 PM
CBRBob's Avatar
SOOOOOOOOO much easier than taking therottle cables off.
CBR Bob
CBRBob is offline
post #5 of 7 Old 03-29-2006, 11:29 PM Thread Starter
i dunno, i'll see what i can do... last time i tried sneaking it out the front i couldnt quite get it past the frame and wiring harness, i'll give it another try before i pull the motor again though
post #6 of 7 Old 03-30-2006, 12:03 AM
I usually pull the wiring harness out of the way. Everything plugs in under the right side air duct cover. Easy to unplug. Honda made it so you can't plug them back in wrong too (different connectors for different things).
Andy
post #7 of 7 Old 03-30-2006, 7:37 AM
I go thru the effort of removing the fuel tank, air filter housing, wire harness etc.Then remove the rad & take it out thru the front.
I like to see what I am doing & it gives me a chance to check every thing out while I am in there.It doesnt take that much longer.
Daryl
KODA93 is offline
Removal of exhaust valve.... 954spider Honda FireBlade 19 05-22-2009 11:28 AM
Valve cover gasket??! Bryce Auten Honda FireBlade 8 02-11-2006 10:43 PM
blowing valve cover gasket Tenshi Wingusu Honda FireBlade 6 09-19-2005 5:24 PM
question about PAIR Valve removal TheShowOff Honda FireBlade 6 07-11-2005 9:54 AM
PAIR valve removal Sirkbac Honda FireBlade 8 09-15-2003 7:09 AM
