HTEV problems - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 03-30-2006, 12:02 AM Thread Starter
HTEV problems
I just picked up an '01 929RR a few weeks ago. It had been flashing code 35, and from my lurking on the forums I pulled the fairings off and checked inside the cover for the HTEV, but no rocks or anything fell out. I tried moving it by hand (Which is where I made a mistake, I think) and it finally rotated a little bit, fairly easily, back and forth. I moved it to the opposite position of where it was, and fired the bike up. I let it run for several minutes, and the light never came on. After I put it all back together, I took it for a ride, but the bike is way down on power, runs poorly below about 6000 rpm, and just surges, but especially right at 3000 rpm. This is not at all like it had been before. It seems to run close to how it did before above 6 or 7k rpm, but it isn't any stronger, for sure, and might be down in power, but below that it is CLEARLY less strong. Did I ruin the servo motor, get the HTEV stuck partway, or something else? Anyone have any hints or ideas? I'm not interested in getting rid of the stock system, I'm fine with the power and sound, I just want it to run smoothly again. It ran fine before, I just wanted to turn the light off, and now it runs poorly. Help! lol Thanks.
dunehog is offline
post #2 of 9 Old 03-30-2006, 12:04 AM
phobiaphobe's Avatar
Reputation Power: 43
Re: HTEV problems
Check the cables, might have one disconnected.
phobiaphobe is offline
post #3 of 9 Old 03-30-2006, 7:41 PM Thread Starter
Re: HTEV problems
I bought a service manual today and pulled the servo out for the HTEV and disassembled it, sure enough there were pieces of gear shrapnel inside the motorbox. My thinking is to take the stripped out gear and head to the hobby shop and see if I can find a replacement. Has any tried this? Failing that, can I order just a set of gears for the servo? The dealer claims not, but they will also get something like 235 bucks for the replacement servo. Chapparral gets about 210 for it, went by there today. What should I do?
dunehog is offline
post #4 of 9 Old 03-30-2006, 8:01 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: HTEV problems
Check RonAyers.com to see if the part is listed on their online fiche. If so, you'll also see what the real cost for it is.
Red Rider is offline
post #5 of 9 Old 03-31-2006, 9:30 AM
CBR929RE's Avatar
Reputation Power: 39
Re: HTEV problems
I had the same problem with my previous 929. Make sure the actual valve in the exhaust is in there correctly and there is nothing making it bind up.
I had the same idea of just trying to replace the gears inside but didn't think of a hobby shop. I'll look around today and see if I still have my old servo motor, maybe we stripped different gears and you can have mine.
CBR929RE is offline
post #6 of 9 Old 03-31-2006, 9:35 AM
Re: HTEV problems
If not you can have mine I just put the Hindle on last night so I have no need for it. You can have it for the price of shipping to ya. Lemme know.
DaveM is offline
post #7 of 9 Old 03-31-2006, 9:48 AM
CBR929RE's Avatar
Re: HTEV problems
did you take the servo motor out? if you take it out you'll have the MIL on the dash lit up all the time.
CBR929RE is offline
post #8 of 9 Old 03-31-2006, 9:52 AM
Re: HTEV problems
No I screwd up after re-reading the post I thought he needed the HTEV. Insert jackass icon here...
DaveM is offline
post #9 of 9 Old 03-31-2006, 12:32 PM Thread Starter
Re: HTEV problems
No, I left the servo motor in and connected, but the MIL is on anyway, though now it shows code 34 instead of 35. The gears that were stripped, on close examination, were the last idler gear and then the final driven gear that actually turns the pulley on the servo motor. In other words, the last two gears in the series, if you count the motor as the beginning. The last gear has only 2 teeth missing, it looks like, but the other gear's small set is completely stripped smooth. No luck with the hobby shop today, but the big one local to me was closed. If I can get the actual gears from another CBR though, that seems better than hoping something else will work. I was able to turn the actual HTEV by hand, there was firm resistance but it was smooth. I'm trying to think of something to compare it to. It was harder to twist than the throttle for sure, by several times. I don't have the manual with me right now, but I recall thinking that the preload on the valve seemed way too high. How do I measure that? (I know with a torque wrench, but on where?) I didn't read it that closely because I was more interested in getting the servo checked out and everything buttoned back up before it started raining.
dunehog is offline
HTEV modification 929rrob Honda FireBlade 16 05-14-2005 12:59 AM
Htev problems buckles Honda FireBlade 3 01-24-2005 3:13 AM
HTEV cables? slowpoke Honda FireBlade 14 02-16-2004 1:57 AM
HTEV question Fossil Honda FireBlade 1 07-13-2003 10:49 PM
HTEV Cliff Honda FireBlade 14 05-22-2003 3:37 PM
