954 hard shifting + skipping neutral - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 03-30-2006, 3:27 PM Thread Starter
could aftermarket aluminum clutch plates (with OEM fiber plates) cause a hard and knotchy shift, most pronounced in 1st to 2nd. Refuses to go into neutral from 1st or 2nd. I'm fairly certain the new plates are the culprit, but wanted to ask around before I dive in. I just replaced the oem steels and this is what I'm experiencing. Shifting was normal before the install. My only thought is I screwed something up in the process, but I've replaced clutches before without mishap.
kc954 is offline
post #2 of 3 Old 03-31-2006, 1:38 PM
allred's Avatar
Reputation Power: 17
Re: 954 hard shifting + skipping neutral
If you had no problem before the clutch plates replacement then by the method of elimination either the new plates are at fault, or you screwed up somewhere along the line during installation. As fitting new clutch plates is pretty simple I would suspect the new plates. I guess an easy way to find out is to put the original OEM steels back in......a pain I know, but the easiest way to find out.
If the clutch was performing fine before, why did you replace the steels anyway?
allred is offline
post #3 of 3 Old 03-31-2006, 9:24 PM Thread Starter
turns out that my friend, who originally bought these plates for his 954 (bike was stolen before he installed them), left out an important detail that they have to be "broken in" with a few high rev launches, and my initial experience is normal. Thats what he said, I already took them out and put the old steels back in. I replaced them because 1) they were free, and 2) less rotating mass in the clutch assembly = faster-reving motor.
kc954 is offline
Neutral -> 1st Abjatrer Honda FireBlade 25 04-04-2011 12:29 PM
Neutral light stays on DS760 Honda FireBlade 0 07-14-2005 2:03 AM
false neutral like a mofo. houston954 Honda FireBlade 41 08-22-2004 10:08 PM
Neutral light fudged 02FBlade Honda FireBlade 2 07-21-2004 2:09 PM
Thinking of skipping RA and going to LS ViciousRR Off-Topic 5 03-26-2004 5:20 PM
