Rattling noise under load, power surges when noise stops - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 04-04-2006, 9:02 AM Thread Starter
107
I've read all the CCT and HTEV posts and am not sure if this is the same problem... I took it to a mechanic and he seems to think it's not the CCT. Basically the engine sounds like steel bearings being thrown at a metal wall... The noise stops completely around 5000-6000rpm's under load, and immediately at that point the bike starts pulling/accelerating a lot harder(even under light throttle). Anyone had this problem and fixed it, or have any ideas what this could be?
107 is offline
post #2 of 23 Old 04-04-2006, 10:52 AM
Re: Rattling noise under load, power surges when noise stops
The only three things I could think of it being are:
1) The CCT (relatively inexpensive to replace, may want to try it to resolve the issue).
2) Clutch (could be your plates chattering, doesn't explain the power surge though).
3) Valves are out of adjustment (will make quite the noise if out of spec, especially with higher revs, but they would always make noise regardless of the rpm's).
Jake is offline
post #3 of 23 Old 04-04-2006, 11:02 AM
I'll bet it's the HTEV. I forget the exact rpm where it opens fully, but it is in the 6000 neighborhood. You may have something caught in the HTEV itself, it may need to be adjusted, or it may just be bad.
BDA116 is offline
post #4 of 23 Old 04-04-2006, 11:49 AM
EatnAsphalt's Avatar
Reputation Power: 19
There is a procedure in the shop manual to test the HTEV (at least to see if it's moving properly). It moves to it's 3rd position around 7k. Has another for 3.5K up to 7k and one below 3.5k.
How many miles do you have on the bike? The only time I've ever heard a motor sound like steel balls hitting a wall was a YZ250 that blew a crank bearing. Lets hope it's not something like that!
Andy
EatnAsphalt is offline
post #5 of 23 Old 04-04-2006, 12:05 PM Thread Starter
107
Thanks guys, hope it's nothing serious- the mechanic also suggested crank bearing but the bike has a little over 9000 miles on it and it's been making this noise since about 2k(I got it used low miles but out of warranty). If it's something serious I would imagine I would have known by now(knock on wood!). It does go away at higher revs, so I doubt the valves- but HTEV and CCT will have to be checked out. I tried changing the CCT myself with no luck, someone suggested pivoting the engine to get to it, which I wasn't ready to do at that point. Thanks for the help- I can see the HTEV finally opening and causing that power surge, but do you think the CCT would also cause a surge at a certain rev range if it was bad?
107 is offline
post #6 of 23 Old 04-04-2006, 6:13 PM Thread Starter
107
It's actually right at 3000 RPM, not 6- and the bike kind of surges at around 2000. Even though it doesn't make a racket in neutral(no load), if I slowly climb RPMS it will get to 3000 and jump to 3500+ very quickly. Not sure if the two are related.
107 is offline
post #7 of 23 Old 04-04-2006, 6:50 PM
Surges with low throttle or no throttle? Mine always has some surging at very low throttle around 2k.
Andy
post #8 of 23 Old 04-05-2006, 9:44 AM
Nope, I doubt the CCT would cause any thing with power surges. I think the others have it nailed with the HTEV (I never think of this being an issue as I have a full exhaust).
Jake is offline
post #9 of 23 Old 04-05-2006, 12:34 PM Thread Starter
107
It's at low throttle. Thanks, yeah I'm pretty sure it's the HTEV now, after playing with it yesterday. Is there an adjustment procedure? I couldn't find one in the service manual. The servo seems to be functioning but perhaps the cables just aren't tight enough(or there's gravel/gunk in the exhaust valve as others had mentioned).
Thanks for all the help everybody!
107 is offline
post #10 of 23 Old 04-05-2006, 1:48 PM
On the bottom of page 5-94 in the service manual.
Andy
post #11 of 23 Old 04-05-2006, 5:05 PM
hi all im new to the honda always had kwacks. i have a slight rattle also on tick over can someone tell me what CCT is HTEV thanks.also does the steering damper from a 04 1000rr fit the 954 as they have same yokes similar tank???
THANKS LEE (UK)
AH read another thread seems to be a common rattle on the blade as its still cold here.still interested to know about the damper though.
Kirbydevil is offline
post #12 of 23 Old 04-05-2006, 5:57 PM
CCT = Cam Chain Tensioner
HTEV = Honda Titanium Exhaust Valve
Couldn't tell you about the damper. I'd suggest contacting a dealer or the manufacturer and get part numbers, if they are different, they are probably not compatable. I'd guess they are not interchangealbe though....
Jake is offline
post #13 of 23 Old 04-05-2006, 5:59 PM
If you're talking about the OEM damper on the '04 1000RR, it may fit but it won't matter at all as the electronics won't be there on the 954.
BDA116 is offline
post #14 of 23 Old 04-09-2006, 7:49 PM Thread Starter
107
Thanks all, I followed the instructions for adjusting the HTEV(would have never looked for them in that section!) and the noise is gone. Bike sounds great. I can't believe I lived with that racket for so long, it was literally embarassing!
107 is offline
post #15 of 23 Old 08-05-2010, 12:14 PM
Thanks so much for all who contributed to this post! I have been worried for 6 months that my engine was failing, and it turns out that my HTEV valve is simply worn and banging like others described. A few bucks to replace. I would have never caught that without this post. Thanks again!
cdn954 is offline
Rattling noise from engine/exhaust Blade_CI Honda FireBlade 7 02-01-2006 11:56 PM
Front brake dragging noise when hot??? rvfbill Honda FireBlade 2 05-30-2005 2:46 AM
Annoying rattling when cold 107 Honda FireBlade 2 09-26-2004 10:52 AM
engine noise tassie_blade Honda FireBlade 6 06-04-2004 3:24 AM
Plastic on plastic rattling noise?? MrX954 Honda FireBlade 4 05-06-2004 9:55 PM
