I am hoping someone had a similar problem with their bike when they change there clutch .here is the deal i replace the clutch in my CBR 929 but when i try to start it it will not start . the bike was running before i replace the clutch. THe MIL light blink 19 times which is the Ignition pulse generator which makes sense casue its in the right crack case so i replace it same problem it will not start and same 19 blink so I check the ECM by puting it in my friends bike and his bike start right up so its not the ECM. its not the spark plug i already check it and its not the fluid pump the gas is moving. I spary starting fluid in and the bike start but its not getting gas
does anyone i have idea what could it be ? :huh:
thank you
thank you
