problems removing camshaft holders? - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 04-27-2006, 7:53 PM Thread Starter
I'm having problems disengaging the three camshaft holders on my engine. I have turned the engine using a socket on the timing rotor bolt so that it aligns with timing mark. I have also unsrewed all 20 camshaft holder bolts slowly and in the correct order. But when i try to remove the holders they are stuck solid? any ideas, thanks
CJ550 is offline
post #2 of 3 Old 04-28-2006, 12:02 AM
Tornado bait's Avatar
Reputation Power: 27
Re: problems removing camshaft holders?
I just recently had mine off and the dowels had them pretty snug. Probably not the best method, but I just eased them up with the tip of a screwdriver. Take very small bites one corner at a time. Or you could snug them back down, rotate the cames so that the lobes are depressing the valves, then loosen the holder bolts again a little at a time in the criss-cross patern and let the valve spring tension help you.
I do all my own stunts.
Tornado bait is offline
post #3 of 3 Old 04-28-2006, 10:13 AM Thread Starter
thanks that did the job as you said i just eased them up slowly with a screwdriver, and to think i was about to take a piece of wood and a hammer to try to force them off from the side probably would have done damage
CJ550 is offline
954 camshaft removal OldBob Honda FireBlade 30 09-03-2010 1:31 AM
??Removing PCIII?? CBR929Junkster General Discussion 9 05-11-2005 4:29 PM
CBR1000RR stock camshaft specs ? mountainmotor Honda FireBlade 1 04-27-2005 11:05 PM
Technical-Head/Camshaft assembly question victoRR Honda FireBlade 15 11-17-2004 12:18 AM
Removing wheels WetShrub Honda FireBlade 6 07-10-2003 6:23 PM
