Dan Kyle forks? - Honda Motorcycles - FireBlades.org
post #1 of 58 Old 04-27-2006, 9:46 PM Thread Starter
Dan Kyle forks?
I forgot to ask him today but what kind of springs does he use in the forks? I can't imagine they are Ohlins for the low price of $440 for everything.
DaveM is offline
post #2 of 58 Old 04-27-2006, 10:05 PM
CBR929RE's Avatar
Reputation Power: 39
Re: Dan Kyle forks?
I've read he uses either Ohlins or RaceTech. not sure on which he chooses first.
CBR929RE is offline
post #3 of 58 Old 04-27-2006, 11:06 PM
Re: Dan Kyle forks?
I just talked to Dan today and he lead me to believe that he doesn't use Race Tech products at all any longer as they are defective.
longtallsally is offline
post #4 of 58 Old 04-27-2006, 11:19 PM
smoothrideronli's Avatar
Re: Dan Kyle forks?
He just put Ohlins inside mine and revalved for a total of $650. Ohlins springs are not that expensive.
smoothrideronli is offline
post #5 of 58 Old 04-27-2006, 11:57 PM Thread Starter
Re: Dan Kyle forks?
They must be a little more expensive than the normal spring he uses. Because he is charging me 440 for revalve and springs plus I need new fork seals and bushings for another 110 for a total of $550. Did you have anything else done besides his "normal work"?
Never mind just noticed that you have the 1K, there's the difference..
DaveM is offline
post #6 of 58 Old 04-28-2006, 12:05 AM
Re: Dan Kyle forks?
No but from what I understand the forks on my bike do need more work than a 929.
post #7 of 58 Old 04-28-2006, 3:57 AM
Re: Dan Kyle forks?
racetech springs retail for 109, ohlins retail for 118 or somewhere around there...
slanger is offline
post #8 of 58 Old 04-28-2006, 6:18 AM
HondaGalToo's Avatar
Reputation Power: 31
Re: Dan Kyle forks?
He used to use both Racetech and Ohlins, but he only uses Ohlins now. They are the same price. I recently had Ohlins installed to replace the Ractechs (needed a lighter spring) and he charged me $100 for the Ohlins forks, same price as the Racetechs I got from him 3 years ago. Sounds like his revalve service went up a whopping $10!
Smoothrideronli is correct, the 1000's forks need more work than the 929/954 to make them right. Seems like Dan can't revalve the stock stuff like he can on the 929/954, I guess in the 1000 he puts in Ohlins valves?
HondaGalToo is offline
post #9 of 58 Old 04-28-2006, 8:44 AM
Re: Dan Kyle forks?
Yep he put all Ohlins internals in mine...and you can call me Smooth for short.
post #10 of 58 Old 04-28-2006, 9:12 AM Thread Starter
Re: Dan Kyle forks?
Sweet so they are the Ohlins springs, Thanks
Man I can't take this waiting for the stuff and it's only been 1 day .
The forks won't be there until next Thursday Stupid UPS wanted and arm and a leg to ship any faster... Oh well it will be worth it
DaveM is offline
post #11 of 58 Old 04-28-2006, 9:15 AM
Re: Dan Kyle forks?
Ok, Smoothie!!!
post #12 of 58 Old 04-28-2006, 9:16 AM
Re: Dan Kyle forks?
I hear that! One week ground there, he does them in one day, but then another week back.
post #13 of 58 Old 04-28-2006, 9:23 AM
Re: Dan Kyle forks?
Originally Posted by HondaGalToo
Ok, Smoothie!!!
post #14 of 58 Old 04-28-2006, 10:15 AM
Re: Dan Kyle forks?
post #15 of 58 Old 04-28-2006, 10:35 AM
Re: Dan Kyle forks?
When I talked to him, he said that he actually still uses the stock valves, but just changes the shim pack to get it right and polishes everything up.
The thing that confused me was that he said he would go from a 10w to a 5w weight. I thought that you would need a thicker oil to compensate for the stiffer and linear rate spring???
Dan Kyle dB Vendor / Seller / Dealer Reviews 6 09-12-2009 8:25 PM
Dan Kyle...... trixskier Honda FireBlade 6 11-28-2005 9:48 PM
Front forks off to Dan Kyle, what about rear shock? 41ants Honda FireBlade 12 08-19-2004 6:45 PM
Dan Kyle dB Honda FireBlade 0 07-18-2003 7:07 PM
