Tired suspension? - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 05-02-2006, 2:11 AM Thread Starter
sam
Reputation Power: 15
Tired suspension?
Anybody know how long the stock suspension can go between rebuilds? I have 12k miles on my '02 954 and it's just feeling "off." Tires are good, pressure good, haven't changed settings...
sam is offline
post #2 of 18 Old 05-02-2006, 2:17 AM
Re: Tired suspension?
Off to DK they go. Sounds like your ready for a freshing up and rebuild with the correct hardware in there this time.
Silent_Assassin is offline
post #3 of 18 Old 05-02-2006, 2:19 AM Thread Starter
sam
"Correct" being...?
sam is offline
post #4 of 18 Old 05-02-2006, 11:49 AM
Originally Posted by sam
"Correct" being...?
"Correct" referring to how they should have come from Honda to begin with. Ohlins internals and Dans thorough knowledge of polishing work, etc. Give him a call. 866-667-4925.
post #5 of 18 Old 05-02-2006, 11:51 AM
dial in the compression and rebound damping for a quick free fix. don't change preload unless sag is execessive.
LUCIDDREAM57 is offline
post #6 of 18 Old 05-02-2006, 11:52 AM
p.s. what are your suspensions settings? how much do you weigh???
post #7 of 18 Old 05-02-2006, 1:14 PM Thread Starter
sam
Thanks for Dan's number (at first, I thought by "DK" you meant Denmark!)
I looked at Ohlins internals last night... not as much $$$ as I'd thought (I know I can't afford full Ohlins replacements!)
RE: my current settings... Since I'm at work at the moment, I don't have 'em. I weigh about 170 (prolly a bit more with leathers), and I'll look up the settings when I get home tonight (or, if I have a long enough break, I'll go out and count turns!)... stand by
sam is offline
post #8 of 18 Old 05-02-2006, 1:19 PM
You'll need some stiffer springs in front to go with a revalve. On a 954, you don't need the Ohlins valving, just a reshimming of the stock valves works great.
Put the money of ohlins valves to an ohlins shock.
If you are short of funds, IMO, best to put in .95kg springs in the front and change the oil (but don't do the revalve), and buy an Ohlins rear.
If you've got about $1500, do the fork revalve and spring and rear shock. It'll be the best money you ever spent on a bike.
luvtolean is offline
post #9 of 18 Old 05-02-2006, 1:56 PM
IF the suspension settings are not all the way in already, just go two turns in and test ride. that will stiffin things up, but again it's only temporary, fork work will be needed eventually.....p.s. i think my stock suspension works great after i dialed it in.........huh, i must be something different from the norm............not sure what yet...........
post #10 of 18 Old 05-02-2006, 2:41 PM Thread Starter
sam
I'm going to do a track day next month, and there'll be some suspension guys on hand to really get it tweaked up. I think I can afford to do some new fork springs/oil prior (the rest of my bux are going to track day right now!)... Meanwhile, I'll try the two turns trick for a ride or three and see where it goes.
So far, it's not bad enough to lose confidence in turns, but I can tell she's headin' that way!
sam is offline
post #11 of 18 Old 05-03-2006, 2:26 AM Thread Starter
sam
OK... I changed rear compression damping. Now all settings are factory default except rear preload:
Front preload: 7T from soft
Front compression damping: 2T from hard
Front rebound damping: 2T from hard
Rear preload: 3 (factory default is 4)
Rear compression damping: 2T from hard (was at 3T from hard)
Rear rebound damping: 2T from hard
I'll see if changing rear comp damping 1 turn is noticable...
Have never touched height/sag (previous owner might have... not sure how to tell )
I also weighed myself with all gear: 188 (in street clothes--no shoes--I'm 172)
Suggestions/thoughts?
sam is offline
post #12 of 18 Old 05-03-2006, 9:31 AM
how does it feel now as opposed to before??
post #13 of 18 Old 05-03-2006, 11:39 AM
I'm about your weight. Just max out the preload on the forks if you have the stock springs. It will still have too much sag, but it will be better.
post #14 of 18 Old 05-04-2006, 12:48 AM Thread Starter
sam
I don't know... I had to take the cage to work today
sam is offline
post #15 of 18 Old 05-04-2006, 1:26 PM Thread Starter
sam
OK... rode today. I'm surprised that a tiny change like that makes that much difference! It's a LOT better!
sam is offline
Tired of sheep crap? Pete Off-Topic 22 04-22-2006 1:35 PM
Tired of high gas prices... CBRBob Off-Topic 24 03-25-2005 11:39 AM
Tired of seeing....... TGZ13 Honda RC51 33 03-02-2005 9:58 PM
Tired of it all.... ND4SPD Off-Topic 27 04-26-2004 2:58 AM
