Sputter - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 05-04-2006, 2:49 AM Thread Starter
Sputter
Well, it's about time I get a simple problem that eludes me. It has to be simple, it's in the fuel system. That and the fact that it's a Carbed 900RR
Cruising along at about 5000 RPM in 6th gear the bike runs great. I would like to say perfect. However, if I get off the throttle and then get right back on it the bike seems to me as if it's loading up. It spits and sputters for a split second and then comes right back to life.
If I take off and run through the gears I never see a single hiccup. Once the bike is back to cruising speed though I'm enduring the same small problem.
I've already been through the usual run-down. The entire electrical system is good and charging properly.
All of the filters are clean. And just for the heck of it I cleaned the Air Filter while it was out of the bike.
The Air-Box is secure and sealed off.
All of the plugs look good as well. (I'm assuming that whatever is causing the stuttering cleans out and takes the evidence with it in regards to trying to read the plugs.)
OH yea, the bike just started this.
I need suggestions.
Custom900 is offline
post #2 of 3 Old 05-04-2006, 11:18 AM
Re: Sputter
Did you just fill up recently?
Could be as simple as a bad batch of gas.
BDA116 is offline
post #3 of 3 Old 05-04-2006, 11:30 AM Thread Starter
Re: Sputter
That's my hope. I did make a trip to a different fuel station than usual.
I just got back from taking a ride to try and dump all of the old fuel. No reason to pull the tank again when I can have a little fun draining the fuel.
The bike still offers me the same response as before, but from a dead stop, leaving hard in first gear it will still loft the front wheel. After all of that settles it will pull hard in second as well.
Running normally down the road however the bike refuses to offer a clean roll on acceleration. It chokes and sputters then cleans itself right back out. So far it only does this in 6th gear at about 4500 and 5000 RPM.
By the way Squid Patrol, I did not run wide open on the Public Roads. I have an old abandon air strip a few miles from my house that I have permission to test at. The great thing, I'm the only one allowed for safety reasons. Life is good. My own personal playground.
