954 and 3000rpm - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-04-2006, 4:34 AM Thread Starter
Reputation Power: 15
954 and 3000rpm
is anyone able to keep the throttle at 3000rpm at neutral!
there is some wierd sh..happening there it jumps up and down. I think this is the reason the 954 is so hard to drive in traffic.
I heard that VRF800 have same problem. Someone cured the problem with Power commander and custom map. But maybe the 954 is more tricky because the exhaust valve is also opening at 3000.
JakeT
JakeT is offline
post #2 of 7 Old 05-04-2006, 4:52 AM
Re: 954 and 3000rpm
synergy is offline
post #3 of 7 Old 05-04-2006, 5:32 AM
Jungleboy's Avatar
Re: 954 and 3000rpm
Yeah it seems to be a standard 954 trait, mine has the flapper, HTEV and pair valve removed and a different map and it still does it
2004 1000RR Racebike
www.jungleboyracing.com
Jungleboy is offline
post #4 of 7 Old 05-04-2006, 7:10 AM Thread Starter
Re: 954 and 3000rpm
I have also heard that hardwiring the clutch switch would cure it? haven't tested it yet.
I think the clutch switch could do some change as I can notice the bike is running differently with gear on compared to neutral, it's like running different map or something. My clutch switch is broken, so I can notice the difference. I think the ecu runs neutral map when the clutch is in or when the bike is in neutral. If your clutch switch is working, you cannot tell the difference between neutral and 1 gear. when the switch is not connected you can notice the difference it makes at 3000.
But if it's a map change, then it should be fixable with powercommander.?
maybe there is some sort of huge increase in the fuel mapping in the ecu at the same time the exhaust valve opens.? It's probably squirting some enrichment during the 3000 to compensate the exhaust opening up? Maybe at neutral map it doesn't use enrichment at all?
But you probably loose some power with the neutral map. There should be a manual switch, so I could use neutral map during traffic. or below 4000?
investigation continues....
JakeT is offline
post #5 of 7 Old 05-04-2006, 7:34 AM
Re: 954 and 3000rpm
I had the same problem on all three of my 954's.
Solution:
PC3, Full Exhaust, BMC Air Filter, O2 Sensor Eliminator, Pair Valve Blockoff, Remove the Flapper inside the Airbox, and most importantly get a custom dynotune.
Getting a fully customized map should cost about $300-400. If they charge less they are doing it wrong. It takes about 4-7 hours on the dyno. Sometimes even longer.
Hope this helps out.
Erion954 is offline
post #6 of 7 Old 05-04-2006, 9:30 AM Thread Starter
Re: 954 and 3000rpm
" customized map should cost about $300-400"
yep, it should, but no point to map the almoust stock bike, I need full system first, and that ain't cheap.!
JakeT is offline
post #7 of 7 Old 05-04-2006, 10:46 AM
Re: 954 and 3000rpm
[quote=JakeT]" customized map should cost about $300-400"
-No Offense but I think you are wrong.
Check out the links below:
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
http://cgi.ebay.com/ebaymotors/MICRO...QQcmdZViewItem
This one is Live right Now.
http://cgi.ebay.com/ebaymotors/Honda...QQcmdZViewItemGreat Deal if you ask me.
I have bought full Ti Arata for $600 shipped
Full Arrow Stainless with Carb Muffler fon $430 shipped
Just my
Erion954 is offline
New to the 954 and need parts and advice hamfisted Honda FireBlade 2 03-22-2006 12:23 AM
WANTED: 954 Swing Arm, brake carrier, and 954 shock linkage Zhart Wanted 0 01-14-2006 4:20 AM
954 Wheels and Weight jbench Honda FireBlade 2 07-15-2004 4:16 PM
954 and 929 interchangible WalkDawg Honda FireBlade 7 07-04-2003 2:43 PM
My 954 and mini-954! MedTechRR Off-Topic 17 06-04-2003 7:46 AM
