929 blade will not turn over - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 06-23-2006, 3:49 PM Thread Starter
I removed my battery to get it charged at a garage. Now that its back in my bike wont start. With the ignition on and killswitch on run i hear the fuel pump come on but when i press starter all i get is a buzzing sound form the starter unit just behind battery. I've tried refitting the battery but no change.
Anyone got any ideas
starman is offline
post #2 of 9 Old 06-23-2006, 6:36 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Re: 929 blade will not turn over
Bad battery? Try replacing it...
Red Rider is offline
post #3 of 9 Old 06-23-2006, 6:42 PM Thread Starter
the garage checked the battery for me and i use an optimate charger and that seems to think battery is good, anything else cause the problem?
The noise coming from the starter is something i've never head before..
starman is offline
post #4 of 9 Old 06-25-2006, 7:21 AM
it's a bad battery. not enough power to start.
what display voltmeter? and what power of the battery in the owner's manual? 12V 10ah?
Graf is offline
post #5 of 9 Old 06-25-2006, 8:03 AM Thread Starter
battery reads 12.5V and is the correct one for the bike. I'm thinking its the battery as well now since even putting indicators on causes the display to go for a second.
Going to garage today to try new battery...I'm able to bump start bike so i'm hoping that what it is.
starman is offline
post #6 of 9 Old 06-25-2006, 8:14 AM
try to off lights before press START button
Graf is offline
post #7 of 9 Old 06-27-2006, 1:16 AM
The start engine consumes a lot of power. If the voltage downs under 11.5 volts when you are pushing the start button the motorcycle will not start and you are consumming the batery charge. You need to replace the batery.
alparrao is offline
post #8 of 9 Old 06-29-2006, 3:21 AM
If you can bump start the bike, it should not be a problem as far as electrical goes past the starting circuit. The buzzing isn't going to be the starter. That's more than likely the starter solenoid. The starter solenoid is an electronic switch that requires a certain amount of voltage to work. The large amount of power the starter motor takes drops the voltage and the solenoid turns off. Once it turns off, there is no load on the battery and the voltage goes back to normal. Thus, the cycle starts over.
Basically, you didn't have to read that. Just buy a new battery and be happy. You can check to make sure it's not the battery by:
1. jump starting - you elimate the batt. If that fixes it, you found the prob.
2. Bump starting it and ride - if the bike dies as you ride, it's not charging it's self. That will lead to the battery dieing. If it dies, you will also need a new stator assembly. (hope it doesn't die)
deltwith is offline
post #9 of 9 Old 06-29-2006, 12:07 PM
Reputation Power: 15
Have you tried giving it a treat or maybe asking it nicely.
No really, the bump start method will work but keep in mind that if the voltage in the batt is extremely low the bike may start that way but may not run right. Always start with the easy stuff, grap a new battery.
NVERL8 is offline
my 929 will not start REBElontw Honda FireBlade 3 04-26-2006 11:19 AM
I have not/will not ever subscribe to the LA Times. RRWANTR Politics 14 01-26-2006 4:28 PM
Euro Blade turn signals wonder_boy Honda FireBlade 8 01-24-2006 12:33 PM
Turn Signals Not working scottzx7rr Honda FireBlade 2 10-28-2005 3:31 PM
929 will not start after valve check Seeker Honda FireBlade 18 08-20-2003 10:20 AM
