Electrical Meltdown!!! - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 06-24-2006, 4:19 AM Thread Starter
CRAP!!!
For the last day or so I have been experiencing a strange burning plastic smell coming from the area of my rectifier. I smelled it a bit last night, but thought it might be the hot weather working the fans a lot making the rectifier smell a little. Didn't see anything wierd, but today it got worse.
When I got home from work it was stronger. I took off the seat and noticed the plastic cover over the wiring harness under the seat had discolored. I took it apart to find the problem. The connector from the stator that connects to the rectifier had melted, and the wires on both sides of the connector were now bare.
When I bought the bike the previous owner said it had recently failed and melted the same connector. One side had been replaced and was plugged into the remaining side that did have a little discoloration as I recall. I'm now wondering if the wires had been damaged causing heat build up.
It has run normally for 3000 miles. This must have just recently happened, possibly hurried alone buy the very high temperatures here in San Fran recently.
My plan is to cut the wires back several inches and replace the burnt sections of the wire on both sides. Then just use male and female ends to connect the rectifier and the stator back together.
What do you think? Might there be others problems that might have caused this? Bad ststor, bad rectifier - again. The battery came out of the bike with over 14 volts in it. so it is definatley charging.
No other electrical problems experienced. No extra electrically powered equipment added to the bike.
melted-1.jpg‎   melted-2.jpg‎
dmack is offline
post #2 of 5 Old 06-24-2006, 4:55 AM
Re: Electrical Meltdown!!!
That has nothing to do with outside temps, you have an electrical problem. You mentioned that the last owner had the same thing happen, you have a short in a wire or component somewhere, you NEED to check each one of the wires in that harness and track down where the problem is. Something is drawing too much current for the wiring, this could be a hard short or a long term problem that heats and heats until a failure. I have seen this many times and it won't go away, you will replace it and it will fail again and again you need to find out the source of the problem.
Start by putting a meter on the wire and find out the draw, something might jump out as way too high then you can follow that wire and find out what is causing the problem, this can be a long process but if you troubleshoot one at a time you will figure it out. Find someone that is a good 12V troubleshooter, I installed car stereos, alarms and car starters for a few years and I had a good side business helping
mechanic friends track down electrical problems like this. Don't assume anyone that can turn a wrench knows how to find this problem.
Good Luck
BladeRider is offline
post #3 of 5 Old 06-24-2006, 12:38 PM
The rectifier died. Honda's will burn up the wiring harness near the rectifier when they go bad.
I've been in your shoes and I didn't like it. It is an easy fix though.
Custom900 is offline
post #4 of 5 Old 06-24-2006, 3:45 PM
definitly too much current through those wires the rectifier/regulator is the most probable cause
cwr954 is offline
post #5 of 5 Old 08-06-2010, 11:54 AM
Reputation Power: 10
Originally Posted by dmack View Post
CRAP!!!
My guess would be your regulator is bad. the regulator-rectifier (RR) regulator side is gone. if it was the stator it would not have a good charge on the battery.
ylem is offline
Electrical problem tutman6 Honda FireBlade 6 05-01-2007 5:52 AM
Electrical problem... sonik_fury Honda FireBlade 0 01-16-2006 7:07 AM
Aries Spears meltdown Tornado bait Off-Topic 5 09-13-2005 10:39 AM
Electrical Question bladerider954 Honda FireBlade 12 07-01-2004 9:09 PM
Electrical problem Mattxp800 Honda FireBlade 4 06-01-2003 5:05 AM
