929 speedo meter problem - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 06-26-2006, 3:27 AM Thread Starter
anyone knows why sometimes my speedo meter dies for les than a sec then comes back on
as if like i toke the key off the ignition and turn it back on
while im driving
is there some thing wrong ???
kinda worried
and it happends from times to times kinda often tho
emazens is offline
post #2 of 7 Old 06-26-2006, 4:39 AM
Re: 929 speedo meter problem
Have you checked the plug? With humidity, vibrations, etc.. maybe it got corroded and the contact isn't 100% anymore.
Hades is offline
post #3 of 7 Old 06-26-2006, 10:36 AM Thread Starter
cool thanx alot man
i hope its only that lol
emazens is offline
post #4 of 7 Old 06-28-2006, 11:48 PM
loose connection to your battery.
zxcv1000 is offline
post #5 of 7 Old 06-29-2006, 1:32 AM
A friend of mine had the same prob, accept his would go off for extended periods of time. It ended up being a wire coming unsoldered from the circuit board inside the instrument assembly , good luck with it.
out ride you is offline
post #6 of 7 Old 07-27-2006, 10:01 PM
HEY THERE EMAZENS, I HAVE THE SAME PROBLEM AS YOU, I'VE HEARD THAT IT MAY BE THE SPEED SENSOR THAT MAY NEED REPLACEMENT. TRY THE OBVIOUS (CABLE CONNECTIONS) IF NOT, MORE THAN LIKELY ITS THE SPEED SENSOR. I'LL LET YOU KNOW IF THAT'S IT (I'M WORKING ON MY BIKE TOMORROW) OR LET ME KNOW IF YOU DO IT FIRST. GOOD LUCK.
BIGSAPOTEER is offline
post #7 of 7 Old 07-27-2006, 10:18 PM Thread Starter
no problrm man
well i didnt do anything on it just just stoped doing it since i stoped putting any water to wash my speedo
i dunnu
emazens is offline
?? Speedo problems on my 929 ?? CBR929Junkster Honda FireBlade 14 07-31-2006 8:16 PM
CBR 929 meter problem Murphy Honda FireBlade 3 01-12-2006 1:15 AM
Does your speedo"meter" do this???? SilverBullet General Discussion 10 07-22-2004 1:54 PM
CBR1000RR speedo problem bidwell Honda FireBlade 45 05-28-2004 3:29 AM
Power/Speedo problem brian48130 Honda Interceptor / VFR 9 05-09-2004 4:21 PM
