929 won't crank - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 06-28-2006, 1:45 PM Thread Starter
929 won't crank
I'm trying to get a wrecked CBR 929 to run again. I'm trying to narrow down the possibilities.
1. the ignition - I ordered a key set for the bike, but recieved the key set from a 1998 CBR 900. (I got screwed.) It has the same wires, but a different plug. Will this ignition work with the computer on the 929 if I just match the wires up?
2. the ECU - Is there any way to see if the ECU is good? I'm trying to figure out what is bad, but without knowing what is good, I'm at a loss. I don't know of anyone else with this bike. If anyone lives around Memphis and would be willing to help, I would be gratefull and willing to compensate. Any help or sujestions on how to test the ECU w/o another bike?
3. the gauge cluster - Will the bike run with out it or not? I've heard that it will and I've heard it won't. Which is it?
I know that's a lot to answer, but I don't want to make multiple threads. Any help would be greatly appreciated.
deltwith is offline
post #2 of 4 Old 06-28-2006, 2:14 PM
Re: 929 won't crank
if it was wrecked there is a good chance the tip over sensor is unplugged, damaged, tilted.
LUCIDDREAM57 is offline
post #3 of 4 Old 06-28-2006, 4:38 PM Thread Starter
Re: 929 won't crank
The bank-angle sensor has been by-passed. The ECU seems to be trying to start, other than turning on the fuel pump. I know the fuel pump is good. The ECU just won't ground out the relay to turn it on. I'm running out of ideas quickly.
deltwith is offline
post #4 of 4 Old 06-28-2006, 7:22 PM Thread Starter
Re: 929 won't crank
Ok, it cranked. It runs. I am now the proud owner of a running 929 motor. I had to hunt down a whole bunch of elecrical gremlins. I did find out some very useful information.
1. you DON'T need the gauge spedo/tach cluster for the bike to run.
2. The ignition off of a 1998 CBR 900 will work on a CBR 929.
3. Remote start is entirely possible on these bikes. (yes, I will draw up a diagram and directions to help you wire one up on your bike.)
4. This motor is amazing. The electrical...another story.
Thanks for everyone's help and as soon as I figure the easiest way to wire a remote start, I'll post it. (minus the info that will help a theif.)
deltwith is offline
929 vs 954 crank JakeT Honda FireBlade 6 11-21-2011 6:50 PM
Bike Died and Now won't Crank... gthotchkiss Honda FireBlade 8 01-08-2006 10:17 PM
929 won't start missionjerry Honda FireBlade 7 10-23-2005 3:52 PM
2001 929 won't start erhunter Honda FireBlade 21 05-14-2005 11:22 AM
929 Knife Edged Crank - Pics Jake Honda FireBlade 9 03-07-2004 11:41 AM
