BIG PROBLEM WITH MY ERION - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 07-02-2006, 11:38 AM Thread Starter
When I start my erion and ride the first few minutes, the gauge works fine. After a few minutes, the red light and F1 light comes on solid, and the speedo, odometer stops working. I changed the main harness yesterday and swapped gauges with my boy and the problem didn't go away Can someone please offer a suggestion? I'm hoping to sell this bike very soon and get the blue/yellow 1000. So far I've spent about 500 bucks on this problem. I even took it to a honda dealer and was told that one of my wires didn't match their schematic and therefore they couldn't go any further with the test. (so they charged me 175 bucks for labor). I did have them check the sensor and they said it was working fine.
20blks is offline
post #2 of 11 Old 07-02-2006, 2:02 PM
EatnAsphalt's Avatar
Reputation Power: 19
Re: BIG PROBLEM WITH MY ERION
Are you getting any codes from the ECM? With the ignition switch on, engine stop switch in the run position, put the side stand down and see if you get the MIL light to blink. If not, you can try reading the ECM's memory for prior codes. To do that, you need to remove the seat. Short the service connector with a wire (paper clip works good), and turn the ignition on. If there ares self diagnostic codes in memory, it should blink.
Andy
EatnAsphalt is offline
post #3 of 11 Old 07-02-2006, 7:53 PM Thread Starter
With the kickstand down and the ignition on, there's no light. But, after riding with the red light and F1 light on, when I put the kickstand down the red light starts to blink.
20blks is offline
post #4 of 11 Old 07-02-2006, 11:01 PM
flea954rr's Avatar
thats the code he's talking about. long blink=10, short blink=1.
example: long blink, long blink, short blink, short blink= 22
if you don't have the service manual, post the # and someone will tell you what it is.
flea954rr is offline
post #5 of 11 Old 07-03-2006, 12:06 PM Thread Starter
Will do today. Thanks a million. I hope we can get this done.
20blks is offline
post #6 of 11 Old 07-04-2006, 10:36 AM Thread Starter
1 long blink and 1 short/quick blink.
20blks is offline
post #7 of 11 Old 07-04-2006, 11:58 AM Thread Starter
So far I disconnected the sensor and checked the harness side of the plug for voltage and everything looks good. My manual suggests to replace the ecm and re-test again. Before I do that, I want to get the test harness. I don't know why I ever took it to the dealer.
20blks is offline
post #8 of 11 Old 07-04-2006, 1:17 PM
1 long, 1 short is 11.
• Loose or poor contact on vehicle speed sensor connector
• Open or short circuit in vehicle speed sensor connector
• Faulty vehicle speed sensor
When you checked the harness side for voltage, did you get 12v between the black/brown (pos) and the green/black (neg)?
Andy
post #9 of 11 Old 07-04-2006, 5:49 PM Thread Starter
Yes, I got the proper voltage.
20blks is offline
post #10 of 11 Old 07-11-2006, 6:36 PM Thread Starter
I just replace my speed sensor and the old one had cracks on both mounting tabs. Could this have caused my problem? Also, is there supposed to be oil on the sensor? I'm assuming so since it's hooked up to the engine.
20blks is offline
post #11 of 11 Old 07-11-2006, 7:04 PM
Yes.
And yes.
BDA116 is offline
need help with a problem on my van stegen Off-Topic 10 03-08-2006 2:10 PM
big pc problem, vid card, and major slowdown stegen Off-Topic 4 05-01-2005 10:12 AM
INJECTION PROBLEM WITH MY '00 929RR ??? jfboy Honda FireBlade 19 08-29-2004 2:47 AM
having a little/big problem in MS Word, please help stopsign Off-Topic 7 03-09-2004 9:26 PM
Anyone have a dyno with Erion full system? jdev Honda FireBlade 7 07-28-2003 9:19 PM
