2nd gear pops out?!! '03 954 - Honda Motorcycles - FireBlades.org
post #1 of 52 Old 07-04-2006, 1:05 PM Thread Starter
After some more road testing, have determined that the tranny only disengages under load in second gear (usually pops into neut.) Can this be adjusted, repaired by user or am I looking at a whole new transmission?
Thanks!
doug hall is offline
post #2 of 52 Old 07-04-2006, 1:51 PM
Sponsor
SilverBullet's Avatar
Reputation Power: 21
Re: 2nd gear pops out?!! '03 954
2nd gear is gone. Same that happened with mine, but 4th also went out. Replace 2nd gear. If you are drag racing, you can send it to us or FBG or Superbike Mike's to have it undercut. I did all gears on mine, but I race every weekend.
SilverBullet is offline
post #3 of 52 Old 07-04-2006, 1:52 PM
You can adjust this back to normal by replacing the gears that have worn dog teeth. 1st and 2nd have a wide ratio and get the most wear. Gears are about $35-70, depending where you get them. A shift fork is likely to be bent from the hammering. That's about $500 and twice that much for labor.
dattaway is offline
post #4 of 52 Old 07-04-2006, 1:59 PM
Sponsor
Yes, I would change the shift forks also....well, I did both times.
post #5 of 52 Old 07-04-2006, 3:57 PM
Yep, the second gear is shot. Hondas are known for this little occurrance.
Custom900 is offline
post #6 of 52 Old 07-04-2006, 4:43 PM
Intimidator's Avatar
Same exact thing happened on mine. It would pop out of 2nd under anything more than 1/2 throttle. It turned out to be a bent fork and was replaced under warranty.
Intimidator is offline
post #7 of 52 Old 07-04-2006, 10:26 PM Thread Starter
Thanks to everyone for their input! I've never been a member of a forum group before. It's great to know that there are people with the same interest who are more knowledgeable than me that I can Q for an honest answer.
Thanks again.
Doug Hall
post #8 of 52 Old 07-05-2006, 4:28 PM Thread Starter
More 2nd gear Q's
Okay, so whats involved in working on the 954 tranny. Am I going to have to drop the motor, (and remove the swing arm as well) flip it and split the case, or is there an access type pan or cover. If I have to remove the motor, then I'd rather go ahead and get all the parts to rebuild the engine while I have it out.
Thanks in advance
post #9 of 52 Old 07-05-2006, 9:52 PM
Sponsor
Re: More 2nd gear Q's
Pull it out!
post #10 of 52 Old 07-06-2006, 12:30 AM
Yep, you get to pull the motor and split the cases. I think the only bike with a cassett or cartridge style tranny is the CBR1000RR in the Honda line.
post #11 of 52 Old 07-06-2006, 2:51 AM
I've had 7 Honda's never had any trouble with the gearbox.
People that have had trouble with 2nd gear is because they are very rough
with the gear changes,
& pull 2nd gear wheelies.
so don't put **** on Honda's, they are the best..
I've had 11 dirt bikes, & 7 road bikes,
never had gear trouble with any off them....
Dutchie is offline
post #12 of 52 Old 07-08-2006, 1:41 AM
Do a bit of Drag Racing on a prepped track with stock gears. That should give you a problem.
...............and anything will last if you baby it. I have a "Sport Bike". This means I can push the limits with it. The Honda's limit is the 2nd gear most times. I'm glad you have had good luck though.
post #13 of 52 Old 07-09-2006, 1:13 AM
Often times, poor shifting technique can lead to the bike dropping out of second gear. It's while jamming it back INTO second gear that ugly things can start to happen (i.e. bent shifter forks and dogs). My old 98 VFR is notorious for this.
I try to squeeze the tank with my knees and time the clutch pull/upshift sequence as smoothly as possible to avoid the shifting problems. The Sato rearsets that i have on my 954 have really smoothed out the shifting action, way beyond what the stock linkage was like. And they look good, too!
monkey is offline
post #14 of 52 Old 07-09-2006, 1:29 AM
What does squeezing the tank have to do with shifting?
post #15 of 52 Old 07-09-2006, 3:47 AM
I WISH YOU LIVED HERE IN OZ & WE WILL SEE WHO BABYS THE BIKE
I'M SICK OFF THIS SITE YOU ALL TALK A LOT OFF CRAP
Dutchie is offline
NOISE IN 2ND GEAR lucho Honda FireBlade 3 02-02-2006 10:03 AM
954 Questions: engine cut-out, low-speed gear changes tofty Honda FireBlade 3 03-21-2005 3:06 PM
929 2nd gear wheelies.... Rynz 929 Honda FireBlade 1 08-19-2003 11:44 PM
