954 panels on 929? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 08-16-2006, 7:00 PM Thread Starter
Send a message via AIM to maxgee Send a message via MSN to maxgee
954 panels on 929?
Anyone think this can be done?
The headlights and tail light look more aggressive on the 954 vs 929.
I know the rear would take a little customization, but what about the front?
maxgee is offline
post #2 of 7 Old 08-16-2006, 7:30 PM
Re: 954 panels on 929?
Can Be Done it was in Cycle World or Cycle News like a month ago I will try to find the article and let you know exactly where it was.
But I believe it would be much easier to mold the 929 Upper fairing to fit the 954 headlight and the tail section to fit the 954 taillight using saw, dremel, bondo and/or fiberglass. Also cheaper.
BladeRider93955 is offline
post #3 of 7 Old 08-16-2006, 7:55 PM Thread Starter
That is an option...
I'm also going to search for the article you mentioned. Thanks!
maxgee is offline
post #4 of 7 Old 08-16-2006, 8:02 PM
CBR929RE's Avatar
Reputation Power: 39
if you can make up some brackets it shouln't be too difficult to get the fairings and headlight to match up. hardest part of that would be getting the headlight in correctly. the tail I believe you have to modify the subframe.
CBR929RE is offline
post #5 of 7 Old 08-16-2006, 9:37 PM
HondaGalToo's Avatar
Reputation Power: 31
It's not even close to the same so it won't bolt right up, but I think with fabrication it can be done. I think someone on this site fit the tailpiece, but I believe it involved welding on a different subframe.
HondaGalToo is offline
post #6 of 7 Old 12-04-2006, 9:53 PM
has anyone by chance found that thread that would show the simplist way in order to swap the 954 head peace over to the 929...i like my 929 but it would be much better off with the 954 headlight...let me know, thanx
BoosteD_BirD70 is offline
post #7 of 7 Old 12-05-2006, 6:27 PM
only way it will work is with the 954 sides, i had a 929 with 954 upper light sides tail, it looked cool but i hated it after i changed it. the 929 **** looks great, all u have to do is make littel brackets from the side of the frame for the sides. its not hard at all. upper stay and headlight harness wroks also.
good luck
decepticon13 is offline
954 tank on 929? ulysses_sc Honda FireBlade 1 10-21-2004 1:08 PM
954 damper on a 929? charkly Honda FireBlade 1 08-25-2004 1:43 AM
A 954 frame on a 929? Paul Honda FireBlade 3 03-15-2004 12:59 PM
954 Tail on a 929? Nodge Riding Gear / Luggage 3 09-23-2003 9:21 PM
954 Swinger on a 929 red929 Honda FireBlade 34 09-12-2003 7:10 PM
