954 would barely start this morning - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 08-21-2006, 6:28 PM Thread Starter
Reputation Power: 15
So Im off to work, go to start my bike and it just keeps trying to start. I said, "Ok I must still be asleep" Try to start it again and it wont start. Starter sounds like normal but doesnt start up. After about 30sec on and off the starter on and off the gas it starts up, idles normal. I take off for work and everything seems fine. Has anyone had this problem? I just put a new air filter on yesterday but right after that I started it, let it run 15 seconds then shut her off. Then this morning happened.
LITEITUP is offline
post #2 of 7 Old 08-21-2006, 6:44 PM
Re: 954 would barely start this morning
You're not riding enough. That was a warning from your bike.
seamus is offline
post #3 of 7 Old 08-21-2006, 6:52 PM Thread Starter
sheeit. Ive put 8k miles on the bike since I got it in mid April.
LITEITUP is offline
post #4 of 7 Old 08-22-2006, 12:11 AM
kawboy69's Avatar
Reputation Power: 19
How many milesare on the bike? when was the last tune up?
If you like to talk **** be sure you have the ass to back it up !! If not SHUT THE FU*K UP !!!!
kawboy69 is offline
post #5 of 7 Old 08-22-2006, 12:02 PM
allred's Avatar
Reputation Power: 17
How old is your battery? I noticed that when my battery started to get old, the bike would crank fairly vigerously but refuse to start.......like the computer was saying...."Hey, there's enough to crank the motor but my programming tells me that I need "x" amount of amps before I send a spark to the plugs, so I'm not going to start". A night of trickle charge would work for a while, but a new battery was the real answer and then the problems went away. I have also seen on this forum tales of people buying new batteries which only lasted 9 months or a year before failing........probably due to "old stock" when bought. So my suggestion if you know your battery is fairly old, a new one may solve your problem?
allred is offline
post #6 of 7 Old 08-22-2006, 2:33 PM Thread Starter
Well theres now 12k mi on the bike. All I have done is change the oil regularly and just changed the air filter, the previous owner just changed oil seeing it only had 4900mi. Everything else is original. The battery has been in there since new so that may be it but it hasnt given any known problems. I havent changed the plugs cause they recommend every like 32k but I was going to go ahead and change those at around 20k.
LITEITUP is offline
post #7 of 7 Old 08-22-2006, 2:46 PM
allred's Avatar
My 954 was a 2002. The original battery lasted about 3 years.....around 6,000 miles. The second battery was just starting to show signs of needing to be replaced in 2006.........at 9,000 miles. Admittedly the bike sat in the garage for a lot of the time, it wasn't a daily driver, but I think it is asking a lot of a battery that size to expect it to last more than 3 years......and if ithe bike sits a lot then 2 years may be the extent of its life.
allred is offline
cold start(how does your 954 start) JakeT Honda FireBlade 21 06-28-2005 11:01 PM
Damn cold this morning!! soon2b954 Off-Topic 42 12-21-2004 4:24 PM
Wife ran over my 954 this morning!?! 03blade General Discussion 30 07-08-2004 7:06 PM
Went down this morning... MedTechRR Off-Topic 19 06-10-2004 8:37 AM
