Fuel Line Problem urgent - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 08-30-2006, 3:07 PM Thread Starter
Ok so i cant figure out for the life of me; i have a 954rr and im trying to reconnect the gas tank; but there are 4 hose; and i have no idea where they go; one of them goes from a singl hose into a T; then theres a big hose which isnt connected to anything and then two that look like they go to fuel rail. can anyone help me out here
reefatx is offline
post #2 of 12 Old 08-30-2006, 5:12 PM
Re: Fuel Line Problem urgent
Take a walk through here . . .
abtech is offline
post #3 of 12 Old 08-30-2006, 5:27 PM Thread Starter
while that does help
it still doesnt show where to connect the cables to? it shows them hovering lol
reefatx is offline
post #4 of 12 Old 08-30-2006, 5:35 PM
Sorry, that link isn't for the 954 (read your profile and saw the F4i).
Look through the index (the 954 is listed under CBR900RR). Maybe there is more detail in the right fiche.
abtech is offline
post #5 of 12 Old 08-30-2006, 5:36 PM
The two that look like they just hang and don't connect to anything DO just hang and don't connect to anything.
The larger fuel hose with the banjo ends connects to the fuel rail with a banjo bolt and the other is the return from the fuel rail.
A factory service manual would help immensely here.
BDA116 is offline
post #6 of 12 Old 08-30-2006, 5:37 PM Thread Starter
yeah i already did that and seticherd it to the 954 and if you look at the tables the lines im talking about are numbers 21, 18 , 20 ; plus the two to the fuel rail i have no idea which hoses go on which holes etc....
reefatx is offline
post #7 of 12 Old 08-30-2006, 5:38 PM
CBR929RE's Avatar
Reputation Power: 39
not really sure why Ab gave you a link to an F4 when you have a 954.
Ron Ayers Motorsports - Discount Motorcycle Parts
little hose from the T connector goes into the fitting on the tank. I believe the other hose thats a little bigger goes onto the fuel pump. hose with brass fiting goes from the fuel rail to the pump and attaches with a banjo bolt. not sure about the 4th, its been awhile.it should be another small one the same size as the one off the T.
CBR929RE is offline
post #8 of 12 Old 08-30-2006, 5:48 PM Thread Starter
so your saying the one that t's two of them go to the tank? and where does the other one go? and also have 3 hoses of about the same size? i dont know which hose goes on which nub? please
reefatx is offline
post #9 of 12 Old 08-30-2006, 5:56 PM
read his profile . . . I started linking a 954, but saw the profile and thought he needed the info for the F4i . . .
abtech is offline
post #10 of 12 Old 08-30-2006, 5:57 PM Thread Starter
well i did fidn the right one but it still lacks where i should be hooking these things up to and which hole is for which hose?
reefatx is offline
post #11 of 12 Old 08-30-2006, 5:58 PM
re-read post number 6 . . .
abtech is offline
post #12 of 12 Old 08-30-2006, 6:04 PM
CBR929RE's Avatar
ok I went out and tried to look up in there but couldn't really see too much (and its too much work to take the damper off to lift up the tank). then I remembered I have the service manual.
large tube is the overflow tube and connects to the bottom of the tank. next to that is a smaller tube, thats the air vent tube (I think thats the one that goes to the T). The fuel return tube goes onto the fuel pump and has a clamp on it, the other end goes to some metal thingy on the left side of the bike just behind the frame and aitbox (so I assume that one should show signs of it having a clamp on the end). then there's the big fuel line with brass blocks on the end that goes from the fuel pump to the fuel rail.
hope that helps.
edit: one of the hoses from the T goes to the bottom of the tank, the other 2 vent to air (one runs all the way to the bottom of the bike)
CBR929RE is offline
Fuel Line Couplers? Trackfan Honda FireBlade 16 03-02-2004 3:49 AM
Fuel Line Disconnect Couplings Beyote Honda FireBlade 9 08-12-2003 10:33 PM
Fuel Line Disconnect Couplings Beyote Honda FireBlade 2 08-12-2003 9:32 PM
Fuel line quick disconnects 2OHOH2 Honda FireBlade 4 08-08-2003 7:28 AM
Fuel Line Size 2001 929rr Honda FireBlade 0 06-26-2003 9:47 PM
